Symbol Shortcuts
3
Symbol Shortcuts
Symbol Shortcuts
Are there keboard shortcuts available for Solidworks for symbols such as centerline, +/-, degree, etc?
i have found a few ALT codes that will work, but i was hoping for something similar to AutoCAD's %%p & %%c.
i know they are out there, at least some, because i have stumbled upon <T#-1> for the number 1 (or any other number) inside a Triangle, also C for Circle & S for Square <S#-5>
thanks in advance!
Mark
RE: Symbol Shortcuts
Matt,
please direct me where in the help to find them.
I have tried keywords symbols, control codes, alt codes, character mapping, etc. but have not found anything online or in solidworks help on where a list of them is located!
i know i can go through & add a symbol from the symbol library to a dimension and then find out what code was used, but there are tons of symbols, and i dont want to go through them all to find the shortcuts
Mark
<GTOL-ANGULAR>    Angularity
<GTOL-BETW>    Between
<GTOL-CIRC>    Circularity(roundness)
<GTOL-CONC>    Concentricity and coaxiality
<GTOL-CYL>    Cylindricity
<GTOL-FLAT>    Flatness
<GTOL-LPROF>    Profile of any line
<GTOL-PARA>    Parallelism
<GTOL-PERP>    Perpendicularity
<GTOL-POSI>    Position
<GTOL-SPROF>    Profile of any surface
<GTOL-SRUN>    Simple runout
<GTOL-SORUN>    Simple runout (open)
<GTOL-STRAIGHT>    Straightness
<GTOL-SYMMETRY>    Symmetry
<GTOL-TRUN>    Total runout
<GTOL-TORUN>    Total runout (open)
<IGTOL-ANGULAR>    Angularity
<IGTOL-CIRC>    Circularity(roundness)
<IGTOL-CONC>    Concentricity and coaxiality
<IGTOL-CYL>    Cylindricity
<IGTOL-FLAT>    Flatness
<IGTOL-LPROF>    Profile of any line
<IGTOL-PARA>    Parallelism
<IGTOL-PERP>    Perpendicularity
<IGTOL-POSI>    Position
<IGTOL-SPROF>    Profile of any surface
<IGTOL-SRUN>    Simple runout
<IGTOL-STRAIGHT>    Straightness
<IGTOL-SYMMETRY>    Symmetry
<IGTOL-TRUN>    Total runout
<MOD-CL>    CenterLine
<MOD-DEG>    Degree
<MOD-DIAM>    Diameter
<MOD-SPHDIA>    Spherical Diameter
<MOD-PM>    Plus/Minus
<MOD-FMC>    Regardless of Feature Size
<MOD-FREES>    Free State
<MOD-LMC>    Least Material Condition
<MOD-MMC>    Maximum Material Condition
<MOD-PTZ>    Projected Tolerance Zone
<MOD-EP>    Encompassing
<MOD-TANP>    Tangent Plane
<MOD-SLP1>    Slope (Up)
<MOD-SLP2>    Slope (Down)
<MOD-SLP3>    Slope (Inverted Down)
<MOD-SLP4>    Slope (Inverted Up)
<MOD-BOX>    Square
<MOD-BOX2>    Square(BS)
<MOD-STT>    Statistical
<MOD-FLT>    Flattened Length
<MOD-PL>    Parting Line
<HOLE-SPOT>    Counterbore(Spotface)
<HOLE-SINK>    Countersink
<HOLE-DEPTH>    Depth/Deep
<HOLE-DIAM>    Diameter
<WELD-BUTT>    Butt
<WELD-BUSQ>    Square Butt
<WELD-BUSV>    Single V Butt
<WELD-BUSB>    Single Bevel Butt
<WELD-BUSVBR>    Single V Butt with Root
<WELD-BUSBR>    Single Bevel Butt with Root
<WELD-BUSU>    Single U Butt
<WELD-BUSJ>    Single J Butt
<WELD-BACK>    Backing Run
<WELD-FILL>    Fillet
<WELD-PLUG>    Plug or Slot
<WELD-SPOT>    Spot
<WELD-SPOTC>    Spot (Centered)
<WELD-SEAM>    Seam
<WELD-SEAMC>    Seam (Centered)
<WELD-JSPT>    JIS Spot
<WELD-JSM>    JIS Seam
<JWELD-BUTT>    Butt
<JWELD-BUSQ>    Square Butt
<JWELD-BUSV>    Single V Butt
<JWELD-BUSB>    Single Bevel Butt
<JWELD-BUSVBR>    Single V Butt with Root
<JWELD-BUSBR>    Single Bevel Butt with Root
<JWELD-BUSU>    Single U Butt
<JWELD-BUSJ>    Single J Butt
<JWELD-BACK>    Backing Run
<JWELD-FILL>    Fillet
<JWELD-PLUG>    Plug or Slot
<JWELD-SPOT>    Spot
<JWELD-SPOTC>    Spot (Centered)
<JWELD-SEAM>    Seam
<JWELD-SEAMC>    Seam (Centered)
<JWELD-JSPT>    JIS Spot
<JWELD-JSM>    JIS Seam
<AWLD-GSQ>    Square
<AWLD-GSCR>    Scarf
<AWLD-GV>    V Groove
<AWLD-GBVL>    Bevel
<AWLD-GU>    U Groove
<AWLD-GJ>    J Groove
<AWLD-GFLV>    Flare-V
<AWLD-GFLB>    Flare-Bevel
<AWLD-FILL>    Fillet
<AWLD-PLUG>    Plug or Slot
<AWLD-STUD>    Stud
<AWLD-SPOT>    Spot or Projection
<AWLD-SPOTC>    Spot or Projection (Centered)
<AWLD-SEAM>    Seam
<AWLD-SEAMC>    Seam (Centered)
<AWLD-NBACK>    Back Fill
<AWLD-SURF>    Surfacing
<AWLD-FEDG>    Flange-Edge
<AWLD-FCOR>    Flange-Corner
<AWLD-SQR>    Consumable Insert
<AWLD-SMELT>    Melt Through
<WLDSA-FLT>    Flat
<WLDSA-CNV>    Convex
<WLDSA-CNC>    Concave
<WLDSA-FFLT>    Fillet with Flat
<WLDSA-FCNV>    Fillet with Convex
<WLDSA-FCNC>    Fillet with Concave
<WLDSI-FLT>    Flat
<WLDSI-CNV>    Convex
<WLDSI-CNC>    Concave
<WLDSI-FFLT>    Fillet with Flat
<WLDSI-FCNV>    Fillet with Convex
<WLDSI-FCNC>    Fillet with Concave
<ASPC-SPV>    Double V Groove Spacer
<ASPC-SPB>    Double Bevel Groove Spacer
<ASPC-SPU>    Double U Groove Spacer
<ASPC-SPJ>    Double J Groove Spacer
<ASPC-SPFV>    Double Flare V Spacer
<ASPC-SPFB>    Double Flare Bevel Spacer
<LAY-PERP>    Perpendicularity
<GGTOL-ANGULAR>    Angularity
<GGTOL-AXIS>    Axes intersection
<GGTOL-CIRC>    Circularity(roundness)
<GGTOL-CONC>    Concentricity and coaxiality
<GGTOL-CYL>    Cylindricity
<GGTOL-FLAT>    Flatness
<GGTOL-LONG>    Longitudinal section profile
<GGTOL-LPROF>    Profile of any line
<GGTOL-PARA>    Parallelism
<GGTOL-PERP>    Perpendicularity
<GGTOL-POSI>    Position
<GGTOL-SPROF>    Profile of any surface
<GGTOL-SRUN>    Simple runout
<GGTOL-STRAIGHT>    Straightness
<GGTOL-SYMMETRY>    Symmetry
<GGTOL-TRUN>    Total runout
<GWLD-FILL>    Fillet
<GWLD-HEAT>    Apply heat
<GWLD-SMOO>    Smooth transition
<GWLD-CSTG>    Chain stagger
<GWLD-KSTG>    Check stagger
<GWLD-NAA>    Not all-around
<GWLD-NUM>    Number (No)
<Key-Key>    Key
<S#-1>    Square 1
<S#-2>    Square 2
<S#-3>    Square 3
<S#-4>    Square 4
<S#-5>    Square 5
<S#-6>    Square 6
<S#-7>    Square 7
<S#-8>    Square 8
<S#-9>    Square 9
<S#-10>    Square 10
<S#-11>    Square 11
<S#-12>    Square 12
<S#-13>    Square 13
<S#-14>    Square 14
<S#-15>    Square 15
<S#-16>    Square 16
<S#-17>    Square 17
<S#-18>    Square 18
<S#-19>    Square 19
<S#-20>    Square 20
<S#-21>    Square 21
<S#-22>    Square 22
<S#-23>    Square 23
<S#-24>    Square 24
<S#-25>    Square 25
<S#-26>    Square 26
<S#-27>    Square 27
<S#-28>    Square 28
<S#-29>    Square 29
<S#-30>    Square 30
<S#-31>    Square 31
<S#-32>    Square 32
<S#-33>    Square 33
<S#-34>    Square 34
<S#-35>    Square 35
<S#-36>    Square 36
<S#-37>    Square 37
<S#-38>    Square 38
<S#-39>    Square 39
<S#-40>    Square 40
<S#-41>    Square 41
<S#-42>    Square 42
<S#-43>    Square 43
<S#-44>    Square 44
<S#-45>    Square 45
<S#-46>    Square 46
<S#-47>    Square 47
<S#-48>    Square 48
<S#-49>    Square 49
<S#-50>    Square 50
<S#-51>    Square 51
<S#-52>    Square 52
<S#-53>    Square 53
<S#-54>    Square 54
<S#-55>    Square 55
<S#-56>    Square 56
<S#-57>    Square 57
<S#-58>    Square 58
<S#-59>    Square 59
<S#-60>    Square 60
<S#-61>    Square 61
<S#-62>    Square 62
<S#-63>    Square 63
<S#-64>    Square 64
<S#-65>    Square 65
<S#-66>    Square 66
<S#-67>    Square 67
<S#-68>    Square 68
<S#-69>    Square 69
<S#-70>    Square 70
<S#-71>    Square 71
<S#-72>    Square 72
<S#-73>    Square 73
<S#-74>    Square 74
<S#-75>    Square 75
<S#-76>    Square 76
<S#-77>    Square 77
<S#-78>    Square 78
<S#-79>    Square 79
<S#-80>    Square 80
<S#-81>    Square 81
<S#-82>    Square 82
<S#-83>    Square 83
<S#-84>    Square 84
<S#-85>    Square 85
<S#-86>    Square 86
<S#-87>    Square 87
<S#-88>    Square 88
<S#-89>    Square 89
<S#-90>    Square 90
<S#-91>    Square 91
<S#-92>    Square 92
<S#-93>    Square 93
<S#-94>    Square 94
<S#-95>    Square 95
<S#-96>    Square 96
<S#-97>    Square 97
<S#-98>    Square 98
<S#-99>    Square 99
<S#P-1>    Square 1
<S#P-2>    Square 2
<S#P-3>    Square 3
<S#P-4>    Square 4
<S#P-5>    Square 5
<S#P-6>    Square 6
<S#P-7>    Square 7
<S#P-8>    Square 8
<S#P-9>    Square 9
<S#P-10>    Square 10
<S#P-11>    Square 11
<S#P-12>    Square 12
<S#P-13>    Square 13
<S#P-14>    Square 14
<S#P-15>    Square 15
<S#P-16>    Square 16
<S#P-17>    Square 17
<S#P-18>    Square 18
<S#P-19>    Square 19
<S#P-20>    Square 20
<S#P-21>    Square 21
<S#P-22>    Square 22
<S#P-23>    Square 23
<S#P-24>    Square 24
<S#P-25>    Square 25
<S#P-26>    Square 26
<S#P-27>    Square 27
<S#P-28>    Square 28
<S#P-29>    Square 29
<S#P-30>    Square 30
<S#P-31>    Square 31
<S#P-32>    Square 32
<S#P-33>    Square 33.
<S#P-34>    Square 34.
<S#P-35>    Square 35
<S#P-36>    Square 36
<S#P-37>    Square 37
<S#P-38>    Square 38
<S#P-39>    Square 39
<S#P-40>    Square 40
<S#P-41>    Square 41
<S#P-42>    Square 42
<S#P-43>    Square 43
<S#P-44>    Square 44
<S#P-45>    Square 45
<S#P-46>    Square 46
<S#P-47>    Square 47
<S#P-48>    Square 48
<S#P-49>    Square 49
<S#P-50>    Square 50
<S#P-51>    Square 51
<S#P-52>    Square 52
<S#P-53>    Square 53
<S#P-54>    Square 54
<S#P-55>    Square 55
<S#P-56>    Square 56
<S#P-57>    Square 57
<S#P-58>    Square 58
<S#P-59>    Square 59
<S#P-60>    Square 60
<S#P-61>    Square 61
<S#P-62>    Square 62
<S#P-63>    Square 63
<S#P-64>    Square 64
<S#P-65>    Square 65
<S#P-66>    Square 66
<S#P-67>    Square 67
<S#P-68>    Square 68
<S#P-69>    Square 69
<S#P-70>    Square 70
<S#P-71>    Square 71
<S#P-72>    Square 72
<S#P-73>    Square 73
<S#P-74>    Square 74
<S#P-75>    Square 75
<S#P-76>    Square 76
<S#P-77>    Square 77
<S#P-78>    Square 78
<S#P-79>    Square 79
<S#P-80>    Square 80
<S#P-81>    Square 81
<S#P-82>    Square 82
<S#P-83>    Square 83
<S#P-84>    Square 84
<S#P-85>    Square 85
<S#P-86>    Square 86
<S#P-87>    Square 87
<S#P-88>    Square 88
<S#P-89>    Square 89
<S#P-90>    Square 90
<S#P-91>    Square 91
<S#P-92>    Square 92
<S#P-93>    Square 93
<S#P-94>    Square 94
<S#P-95>    Square 95
<S#P-96>    Square 96
<S#P-97>    Square 97
<S#P-98>    Square 98
<S#P-99>    Square 99
<T#-1>    Triangle 1
<T#-2>    Triangle 2
<T#-3>    Triangle 3
<T#-4>    Triangle 4
<T#-5>    Triangle 5
<T#-6>    Triangle 6
<T#-7>    Triangle 7
<T#-8>    Triangle 8
<T#-9>    Triangle 9
<T#-10>    Triangle 10
<T#-11>    Triangle 11
<T#-12>    Triangle 12
<T#-13>    Triangle 13
<T#-14>    Triangle 14
<T#-15>    Triangle 15
<T#-16>    Triangle 16
<T#-17>    Triangle 17
<T#-18>    Triangle 18
<T#-19>    Triangle 19
<T#-20>    Triangle 20
<T#-21>    Triangle 21
<T#-22>    Triangle 22
<T#-23>    Triangle 23
<T#-24>    Triangle 24
<T#-25>    Triangle 25
<T#-26>    Triangle 26
<T#-27>    Triangle 27
<T#-28>    Triangle 28
<T#-29>    Triangle 29
<T#-30>    Triangle 30
<T#-31>    Triangle 31
<T#-32>    Triangle 32
<T#-33>    Triangle 33
<T#-34>    Triangle 34
<T#-35>    Triangle 35
<T#-36>    Triangle 36
<T#-37>    Triangle 37
<T#-38>    Triangle 38
<T#-39>    Triangle 39
<T#-40>    Triangle 40
<T#-41>    Triangle 41
<T#-42>    Triangle 42
<T#-43>    Triangle 43
<T#-44>    Triangle 44
<T#-45>    Triangle 45
<T#-46>    Triangle 46
<T#-47>    Triangle 47
<T#-48>    Triangle 48
<T#-49>    Triangle 49
<T#-50>    Triangle 50
<T#-51>    Triangle 51
<T#-52>    Triangle 52
<T#-53>    Triangle 53
<T#-54>    Triangle 54
<T#-55>    Triangle 55
<T#-56>    Triangle 56
<T#-57>    Triangle 57
<T#-58>    Triangle 58
<T#-59>    Triangle 59
<T#-60>    Triangle 60
<T#-61>    Triangle 61
<T#-62>    Triangle 62
<T#-63>    Triangle 63
<T#-64>    Triangle 64
<T#-65>    Triangle 65
<T#-66>    Triangle 66
<T#-67>    Triangle 67
<T#-68>    Triangle 68
<T#-69>    Triangle 69
<T#-70>    Triangle 70
<T#-71>    Triangle 71
<T#-72>    Triangle 72
<T#-73>    Triangle 73
<T#-74>    Triangle 74
<T#-75>    Triangle 75
<T#-76>    Triangle 76
<T#-77>    Triangle 77
<T#-78>    Triangle 78
<T#-79>    Triangle 79
<T#-80>    Triangle 80
<T#-81>    Triangle 81
<T#-82>    Triangle 82
<T#-83>    Triangle 83
<T#-84>    Triangle 84
<T#-85>    Triangle 85
<T#-86>    Triangle 86
<T#-87>    Triangle 87
<T#-88>    Triangle 88
<T#-89>    Triangle 89
<T#-90>    Triangle 90
<T#-91>    Triangle 91
<T#-92>    Triangle 92
<T#-93>    Triangle 93
<T#-94>    Triangle 94
<T#-95>    Triangle 95
<T#-96>    Triangle 96
<T#-97>    Triangle 97
<T#-98>    Triangle 98
<T#-99>    Triangle 99
<T#P-1>    Triangle 1
<T#P-2>    Triangle 2
<T#P-3>    Triangle 3
<T#P-4>    Triangle 4
<T#P-5>    Triangle 5
<T#P-6>    Triangle 6
<T#P-7>    Triangle 7
<T#P-8>    Triangle 8
<T#P-9>    Triangle 9
<T#P-10>    Triangle 10
<T#P-11>    Triangle 11
<T#P-12>    Triangle 12
<T#P-13>    Triangle 13
<T#P-14>    Triangle 14
<T#P-15>    Triangle 15
<T#P-16>    Triangle 16
<T#P-17>    Triangle 17
<T#P-18>    Triangle 18
<T#P-19>    Triangle 19
<T#P-20>    Triangle 20
<T#P-21>    Triangle 21
<T#P-22>    Triangle 22
<T#P-23>    Triangle 23
<T#P-24>    Triangle 24
<T#P-25>    Triangle 25
<T#P-26>    Triangle 26
<T#P-27>    Triangle 27
<T#P-28>    Triangle 28
<T#P-29>    Triangle 29
<T#P-30>    Triangle 30
<T#P-31>    Triangle 31
<T#P-32>    Triangle 32
<T#P-33>    Triangle 33
<T#P-34>    Triangle 34
<T#P-35>    Triangle 35
<T#P-36>    Triangle 36
<T#P-37>    Triangle 37
<T#P-38>    Triangle 38
<T#P-39>    Triangle 39
<T#P-40>    Triangle 40
<T#P-41>    Triangle 41
<T#P-42>    Triangle 42
<T#P-43>    Triangle 43
<T#P-44>    Triangle 44
<T#P-45>    Triangle 45
<T#P-46>    Triangle 46
<T#P-47>    Triangle 47
<T#P-48>    Triangle 48
<T#P-49>    Triangle 49
<T#P-50>    Triangle 50
<T#P-51>    Triangle 51
<T#P-52>    Triangle 52
<T#P-53>    Triangle 53
<T#P-54>    Triangle 54
<T#P-55>    Triangle 55
<T#P-56>    Triangle 56
<T#P-57>    Triangle 57
<T#P-58>    Triangle 58
<T#P-59>    Triangle 59
<T#P-60>    Triangle 60
<T#P-61>    Triangle 61
<T#P-62>    Triangle 62
<T#P-63>    Triangle 63
<T#P-64>    Triangle 64
<T#P-65>    Triangle 65
<T#P-66>    Triangle 66
<T#P-67>    Triangle 67
<T#P-68>    Triangle 68
<T#P-69>    Triangle 69
<T#P-70>    Triangle 70
<T#P-71>    Triangle 71
<T#P-72>    Triangle 72
<T#P-73>    Triangle 73
<T#P-74>    Triangle 74
<T#P-75>    Triangle 75
<T#P-76>    Triangle 76
<T#P-77>    Triangle 77
<T#P-78>    Triangle 78
<T#P-79>    Triangle 79
<T#P-80>    Triangle 80
<T#P-81>    Triangle 81
<T#P-82>    Triangle 82
<T#P-83>    Triangle 83
<T#P-84>    Triangle 84
<T#P-85>    Triangle 85
<T#P-86>    Triangle 86
<T#P-87>    Triangle 87
<T#P-88>    Triangle 88
<T#P-89>    Triangle 89
<T#P-90>    Triangle 90
<T#P-91>    Triangle 91
<T#P-92>    Triangle 92
<T#P-93>    Triangle 93
<T#P-94>    Triangle 94
<T#P-95>    Triangle 95
<T#P-96>    Triangle 96
<T#P-97>    Triangle 97
<T#P-98>    Triangle 98
<T#P-99>    Triangle 99
<FlagNotes-Flag-1>    Triangle-rotated  1
<FlagNotes-Flag-2>    Triangle-rotated  2
<FlagNotes-Flag-3>    Triangle-rotated  3
<FlagNotes-Flag-4>    Triangle-rotated  4
<FlagNotes-Flag-5>    Triangle-rotated  5
<FlagNotes-Flag-6>    Triangle-rotated  6
<FlagNotes-Flag-7>    Triangle-rotated  7
<FlagNotes-Flag-8>    Triangle-rotated  8
<FlagNotes-Flag-9>    Triangle-rotated  9
<FlagNotes-Flag-10>    Triangle-rotated  10
<FlagNotes-Flag-11>    Triangle-rotated  11
<FlagNotes-Flag-12>    Triangle-rotated  12
<FlagNotes-Flag-13>    Triangle-rotated  13
<FlagNotes-Flag-14>    Triangle-rotated  14
<FlagNotes-Flag-15>    Triangle-rotated  15
<FlagNotes-Flag-16>    Triangle-rotated  16
<FlagNotes-Flag-17>    Triangle-rotated  17
<FlagNotes-Flag-18>    Triangle-rotated  18
<FlagNotes-Flag-19>    Triangle-rotated  19
<FlagNotes-Flag-20>    Triangle-rotated  20
<FlagNotes-Flag-21>    Triangle-rotated  21
<FlagNotes-Flag-22>    Triangle-rotated  22
<FlagNotes-Flag-23>    Triangle-rotated  23
<FlagNotes-Flag-24>    Triangle-rotated  24
<FlagNotes-Flag-25>    Triangle-rotated  25
<FlagNotes-Flag-26>    Triangle-rotated  26
<FlagNotes-Flag-27>    Triangle-rotated  27
<FlagNotes-Flag-28>    Triangle-rotated  28
<FlagNotes-Flag-29>    Triangle-rotated  29
<FlagNotes-Flag-30>    Triangle-rotated  30
<FlagNotes-Flag-31>    Triangle-rotated  31
<FlagNotes-Flag-32>    Triangle-rotated  32
<FlagNotes-Flag-33>    Triangle-rotated  33
<FlagNotes-Flag-34>    Triangle-rotated  34
<FlagNotes-Flag-35>    Triangle-rotated  35
<FlagNotes-Flag-36>    Triangle-rotated  36
<FlagNotes-Flag-37>    Triangle-rotated  37
<FlagNotes-Flag-38>    Triangle-rotated  38
<FlagNotes-Flag-39>    Triangle-rotated  39
<FlagNotes-Flag-40>    Triangle-rotated  40
<FlagNotes-Flag-41>    Triangle-rotated  41
<FlagNotes-Flag-42>    Triangle-rotated  42
<FlagNotes-Flag-43>    Triangle-rotated  43
<FlagNotes-Flag-44>    Triangle-rotated  44
<FlagNotes-Flag-45>    Triangle-rotated  45
<FlagNotes-Flag-46>    Triangle-rotated  46
<FlagNotes-Flag-47>    Triangle-rotated  47
<FlagNotes-Flag-48>    Triangle-rotated  48
<FlagNotes-Flag-49>    Triangle-rotated  49
<FlagNotes-Flag-50>    Triangle-rotated  50
<FlagNotes-Flag-51>    Triangle-rotated   51
<FlagNotes-Flag-52>    Triangle-rotated   52
<FlagNotes-Flag-53>    Triangle-rotated   53
<FlagNotes-Flag-54>    Triangle-rotated   54
<FlagNotes-Flag-55>    Triangle-rotated   55
<FlagNotes-Flag-56>    Triangle-rotated   56
<FlagNotes-Flag-57>    Triangle-rotated   57
<FlagNotes-Flag-58>    Triangle-rotated   58
<FlagNotes-Flag-59>    Triangle-rotated   59
<FlagNotes-Flag-60>    Triangle-rotated   60
<FlagNotes-Flag-61>    Triangle-rotated   61
<FlagNotes-Flag-62>    Triangle-rotated   62
<FlagNotes-Flag-63>    Triangle-rotated   63
<FlagNotes-Flag-64>    Triangle-rotated   64
<FlagNotes-Flag-65>    Triangle-rotated   65
<FlagNotes-Flag-66>    Triangle-rotated   66
<FlagNotes-Flag-67>    Triangle-rotated   67
<FlagNotes-Flag-68>    Triangle-rotated   68
<FlagNotes-Flag-69>    Triangle-rotated   69
<FlagNotes-Flag-70>    Triangle-rotated   70
<FlagNotes-Flag-71>    Triangle-rotated   71
<FlagNotes-Flag-72>    Triangle-rotated   72
<FlagNotes-Flag-73>    Triangle-rotated   73
<FlagNotes-Flag-74>    Triangle-rotated   74
<FlagNotes-Flag-75>    Triangle-rotated   75
<FlagNotes-Flag-76>    Triangle-rotated   76
<FlagNotes-Flag-77>    Triangle-rotated   77
<FlagNotes-Flag-78>    Triangle-rotated   78
<FlagNotes-Flag-79>    Triangle-rotated   79
<FlagNotes-Flag-80>    Triangle-rotated   80
<FlagNotes-Flag-81>    Triangle-rotated   81
<FlagNotes-Flag-82>    Triangle-rotated   82
<FlagNotes-Flag-83>    Triangle-rotated   83
<FlagNotes-Flag-84>    Triangle-rotated   84
<FlagNotes-Flag-85>    Triangle-rotated   85
<FlagNotes-Flag-86>    Triangle-rotated   86
<FlagNotes-Flag-87>    Triangle-rotated   87
<FlagNotes-Flag-88>    Triangle-rotated   88
<FlagNotes-Flag-89>    Triangle-rotated   89
<FlagNotes-Flag-90>    Triangle-rotated   90
<FlagNotes-Flag-91>    Triangle-rotated   91
<FlagNotes-Flag-92>    Triangle-rotated   92
<FlagNotes-Flag-93>    Triangle-rotated   93
<FlagNotes-Flag-94>    Triangle-rotated   94
<FlagNotes-Flag-95>    Triangle-rotated   95
<FlagNotes-Flag-96>    Triangle-rotated   96
<FlagNotes-Flag-97>    Triangle-rotated   97
<FlagNotes-Flag-98>    Triangle-rotated   98
<FlagNotes-Flag-99>    Triangle-rotated   99
<FlagNotes#NPer-Flag-1>    Triangle-rotated  1
<FlagNotes#NPer-Flag-2>    Triangle-rotated  2
<FlagNotes#NPer-Flag-3>    Triangle-rotated  3
<FlagNotes#NPer-Flag-4>    Triangle-rotated  4
<FlagNotes#NPer-Flag-5>    Triangle-rotated  5
<FlagNotes#NPer-Flag-6>    Triangle-rotated  6
<FlagNotes#NPer-Flag-7>    Triangle-rotated  7
<FlagNotes#NPer-Flag-8>    Triangle-rotated  8
<FlagNotes#NPer-Flag-9>    Triangle-rotated  9
<FlagNotes#NPer-Flag-10>    Triangle-rotated  10
<FlagNotes#NPer-Flag-11>    Triangle-rotated  11
<FlagNotes#NPer-Flag-12>    Triangle-rotated  12
<FlagNotes#NPer-Flag-13>    Triangle-rotated  13
<FlagNotes#NPer-Flag-14>    Triangle-rotated  14
<FlagNotes#NPer-Flag-15>    Triangle-rotated  15
<FlagNotes#NPer-Flag-16>    Triangle-rotated  16
<FlagNotes#NPer-Flag-17>    Triangle-rotated  17
<FlagNotes#NPer-Flag-18>    Triangle-rotated  18
<FlagNotes#NPer-Flag-19>    Triangle-rotated  19
<FlagNotes#NPer-Flag-20>    Triangle-rotated  20
<FlagNotes#NPer-Flag-21>    Triangle-rotated  21
<FlagNotes#NPer-Flag-22>    Triangle-rotated  22
<FlagNotes#NPer-Flag-23>    Triangle-rotated  23
<FlagNotes#NPer-Flag-24>    Triangle-rotated  24
<FlagNotes#NPer-Flag-25>    Triangle-rotated  25
<FlagNotes#NPer-Flag-26>    Triangle-rotated  26
<FlagNotes#NPer-Flag-27>    Triangle-rotated  27
<FlagNotes#NPer-Flag-28>    Triangle-rotated  28
<FlagNotes#NPer-Flag-29>    Triangle-rotated  29
<FlagNotes#NPer-Flag-30>    Triangle-rotated  30
<FlagNotes#NPer-Flag-31>    Triangle-rotated  31
<FlagNotes#NPer-Flag-32>    Triangle-rotated  32
<FlagNotes#NPer-Flag-33>    Triangle-rotated  33
<FlagNotes#NPer-Flag-34>    Triangle-rotated  34
<FlagNotes#NPer-Flag-35>    Triangle-rotated  35
<FlagNotes#NPer-Flag-36>    Triangle-rotated  36
<FlagNotes#NPer-Flag-37>    Triangle-rotated  37
<FlagNotes#NPer-Flag-38>    Triangle-rotated  38
<FlagNotes#NPer-Flag-39>    Triangle-rotated  39
<FlagNotes#NPer-Flag-40>    Triangle-rotated  40
<FlagNotes#NPer-Flag-41>    Triangle-rotated  41
<FlagNotes#NPer-Flag-42>    Triangle-rotated  42
<FlagNotes#NPer-Flag-43>    Triangle-rotated  43
<FlagNotes#NPer-Flag-44>    Triangle-rotated  44
<FlagNotes#NPer-Flag-45>    Triangle-rotated  45
<FlagNotes#NPer-Flag-46>    Triangle-rotated  46
<FlagNotes#NPer-Flag-47>    Triangle-rotated  47
<FlagNotes#NPer-Flag-48>    Triangle-rotated  48
<FlagNotes#NPer-Flag-49>    Triangle-rotated  49
<FlagNotes#NPer-Flag-50>    Triangle-rotated  50
<FlagNotes#NPer-Flag-51>    Triangle-rotated   51
<FlagNotes#NPer-Flag-52>    Triangle-rotated   52
<FlagNotes#NPer-Flag-53>    Triangle-rotated   53
<FlagNotes#NPer-Flag-54>    Triangle-rotated   54
<FlagNotes#NPer-Flag-55>    Triangle-rotated   55
<FlagNotes#NPer-Flag-56>    Triangle-rotated   56
<FlagNotes#NPer-Flag-57>    Triangle-rotated   57
<FlagNotes#NPer-Flag-58>    Triangle-rotated   58
<FlagNotes#NPer-Flag-59>    Triangle-rotated   59
<FlagNotes#NPer-Flag-60>    Triangle-rotated   60
<FlagNotes#NPer-Flag-61>    Triangle-rotated   61
<FlagNotes#NPer-Flag-62>    Triangle-rotated   62
<FlagNotes#NPer-Flag-63>    Triangle-rotated   63
<FlagNotes#NPer-Flag-64>    Triangle-rotated   64
<FlagNotes#NPer-Flag-65>    Triangle-rotated   65
<FlagNotes#NPer-Flag-66>    Triangle-rotated   66
<FlagNotes#NPer-Flag-67>    Triangle-rotated   67
<FlagNotes#NPer-Flag-68>    Triangle-rotated   68
<FlagNotes#NPer-Flag-69>    Triangle-rotated   69
<FlagNotes#NPer-Flag-70>    Triangle-rotated   70
<FlagNotes#NPer-Flag-71>    Triangle-rotated   71
<FlagNotes#NPer-Flag-72>    Triangle-rotated   72
<FlagNotes#NPer-Flag-73>    Triangle-rotated   73
<FlagNotes#NPer-Flag-74>    Triangle-rotated   74
<FlagNotes#NPer-Flag-75>    Triangle-rotated   75
<FlagNotes#NPer-Flag-76>    Triangle-rotated   76
<FlagNotes#NPer-Flag-77>    Triangle-rotated   77
<FlagNotes#NPer-Flag-78>    Triangle-rotated   78
<FlagNotes#NPer-Flag-79>    Triangle-rotated   79
<FlagNotes#NPer-Flag-80>    Triangle-rotated   80
<FlagNotes#NPer-Flag-81>    Triangle-rotated   81
<FlagNotes#NPer-Flag-82>    Triangle-rotated   82
<FlagNotes#NPer-Flag-83>    Triangle-rotated   83
<FlagNotes#NPer-Flag-84>    Triangle-rotated   84
<FlagNotes#NPer-Flag-85>    Triangle-rotated   85
<FlagNotes#NPer-Flag-86>    Triangle-rotated   86
<FlagNotes#NPer-Flag-87>    Triangle-rotated   87
<FlagNotes#NPer-Flag-88>    Triangle-rotated   88
<FlagNotes#NPer-Flag-89>    Triangle-rotated   89
<FlagNotes#NPer-Flag-90>    Triangle-rotated   90
<FlagNotes#NPer-Flag-91>    Triangle-rotated   91
<FlagNotes#NPer-Flag-92>    Triangle-rotated   92
<FlagNotes#NPer-Flag-93>    Triangle-rotated   93
<FlagNotes#NPer-Flag-94>    Triangle-rotated   94
<FlagNotes#NPer-Flag-95>    Triangle-rotated   95
<FlagNotes#NPer-Flag-96>    Triangle-rotated   96
<FlagNotes#NPer-Flag-97>    Triangle-rotated   97
<FlagNotes#NPer-Flag-98>    Triangle-rotated   98
<FlagNotes#NPer-Flag-99>    Triangle-rotated   99
<FlagNotes#noper-Flag-1>    Triangle-rotated  A
<FlagNotes#noper-Flag-2>    Triangle-rotated  B
<FlagNotes#noper-Flag-3>    Triangle-rotated  C
<FlagNotes#noper-Flag-4>    Triangle-rotated  D
<FlagNotes#noper-Flag-5>    Triangle-rotated  E
<FlagNotes#noper-Flag-6>    Triangle-rotated  F
<FlagNotes#noper-Flag-7>    Triangle-rotated  G
<FlagNotes#noper-Flag-8>    Triangle-rotated  H
<FlagNotes#noper-Flag-9>    Triangle-rotated  I
<FlagNotes#noper-Flag-10>    Triangle-rotated  J
<FlagNotes#noper-Flag-11>    Triangle-rotated  K
<FlagNotes#noper-Flag-12>    Triangle-rotated  L
<FlagNotes#noper-Flag-13>    Triangle-rotated  M
<FlagNotes#noper-Flag-14>    Triangle-rotated  N
<FlagNotes#noper-Flag-15>    Triangle-rotated  O
<FlagNotes#noper-Flag-16>    Triangle-rotated  P
<FlagNotes#noper-Flag-17>    Triangle-rotated  Q
<FlagNotes#noper-Flag-18>    Triangle-rotated  R
<FlagNotes#noper-Flag-19>    Triangle-rotated  S
<FlagNotes#noper-Flag-20>    Triangle-rotated  T
<FlagNotes#noper-Flag-21>    Triangle-rotated  U
<FlagNotes#noper-Flag-22>    Triangle-rotated  V
<FlagNotes#noper-Flag-23>    Triangle-rotated  W
<FlagNotes#noper-Flag-24>    Triangle-rotated  X
<FlagNotes#noper-Flag-25>    Triangle-rotated  Y
<FlagNotes#noper-Flag-26>    Triangle-rotated  Z
<FlagNotes# az-Flag-1>    Triangle-rotated  A
<FlagNotes# az-Flag-2>    Triangle-rotated  B
<FlagNotes# az-Flag-3>    Triangle-rotated  C
<FlagNotes# az-Flag-4>    Triangle-rotated  D
<FlagNotes# az-Flag-5>    Triangle-rotated  E
<FlagNotes# az-Flag-6>    Triangle-rotated  F
<FlagNotes# az-Flag-7>    Triangle-rotated  G
<FlagNotes# az-Flag-8>    Triangle-rotated  H
<FlagNotes# az-Flag-9>    Triangle-rotated  I
<FlagNotes# az-Flag-10>    Triangle-rotated  J
<FlagNotes# az-Flag-11>    Triangle-rotated  K
<FlagNotes# az-Flag-12>    Triangle-rotated  L
<FlagNotes# az-Flag-13>    Triangle-rotated  M
<FlagNotes# az-Flag-14>    Triangle-rotated  N
<FlagNotes# az-Flag-15>    Triangle-rotated  O
<FlagNotes# az-Flag-16>    Triangle-rotated  P
<FlagNotes# az-Flag-17>    Triangle-rotated  Q
<FlagNotes# az-Flag-18>    Triangle-rotated  R
<FlagNotes# az-Flag-19>    Triangle-rotated  S
<FlagNotes# az-Flag-20>    Triangle-rotated  T
<FlagNotes# az-Flag-21>    Triangle-rotated  U
<FlagNotes# az-Flag-22>    Triangle-rotated  V
<FlagNotes# az-Flag-23>    Triangle-rotated  W
<FlagNotes# az-Flag-24>    Triangle-rotated  X
<FlagNotes# az-Flag-25>    Triangle-rotated  Y
<FlagNotes# az-Flag-26>    Triangle-rotated  Z
<SC#-1>    Square/Circle 1
<SC#-2>    Square/Circle 2
<SC#-3>    Square/Circle 3
<SC#-4>    Square/Circle 4
<SC#-5>    Square/Circle 5
<SC#-6>    Square/Circle 6
<SC#-7>    Square/Circle 7
<SC#-8>    Square/Circle 8
<SC#-9>    Square/Circle 9
<SC#-10>    Square/Circle 10
<SC#-11>    Square/Circle 11
<SC#-12>    Square/Circle 12
<SC#-13>    Square/Circle 13
<SC#-14>    Square/Circle 14
<SC#-15>    Square/Circle 15
<SC#-16>    Square/Circle 16
<SC#-17>    Square/Circle 17
<SC#-18>    Square/Circle 18
<SC#-19>    Square/Circle 19
<SC#-20>    Square/Circle 20
<SC#-21>    Square/Circle 21
<SC#-22>    Square/Circle 22
<SC#-23>    Square/Circle 23
<SC#-24>    Square/Circle 24
<SC#-25>    Square/Circle 25
<SC#-26>    Square/Circle 26
<SC#-27>    Square/Circle 27
<SC#-28>    Square/Circle 28
<SC#-29>    Square/Circle 29
<SC#-30>    Square/Circle 30
<SC#-31>    Square/Circle 31
<SC#-32>    Square/Circle 32
<SC#-33>    Square/Circle 33
<SC#-34>    Square/Circle 34
<SC#-35>    Square/Circle 35
<SC#-36>    Square/Circle 36
<SC#-37>    Square/Circle 37
<SC#-38>    Square/Circle 38
<SC#-39>    Square/Circle 39
<SC#-40>    Square/Circle 40
<SC#-41>    Square/Circle 41
<SC#-42>    Square/Circle 42
<SC#-43>    Square/Circle 43
<SC#-44>    Square/Circle 44
<SC#-45>    Square/Circle 45
<SC#-46>    Square/Circle 46
<SC#-47>    Square/Circle 47
<SC#-48>    Square/Circle 48
<SC#-49>    Square/Circle 49
<SC#-50>    Square/Circle 50
<SC#-51>    Square/Circle 51
<SC#-52>    Square/Circle 52
<SC#-53>    Square/Circle 53
<SC#-54>    Square/Circle 54
<SC#-55>    Square/Circle 55
<SC#-56>    Square/Circle 56
<SC#-57>    Square/Circle 57
<SC#-58>    Square/Circle 58
<SC#-59>    Square/Circle 59
<SC#-60>    Square/Circle 60
<SC#-61>    Square/Circle 61
<SC#-62>    Square/Circle 62
<SC#-63>    Square/Circle 63
<SC#-64>    Square/Circle 64
<SC#-65>    Square/Circle 65
<SC#-66>    Square/Circle 66
<SC#-67>    Square/Circle 67
<SC#-68>    Square/Circle 68
<SC#-69>    Square/Circle 69
<SC#-70>    Square/Circle 70
<SC#-71>    Square/Circle 71
<SC#-72>    Square/Circle 72
<SC#-73>    Square/Circle 73
<SC#-74>    Square/Circle 74
<SC#-75>    Square/Circle 75
<SC#-76>    Square/Circle 76
<SC#-77>    Square/Circle 77
<SC#-78>    Square/Circle 78
<SC#-79>    Square/Circle 79
<SC#-80>    Square/Circle 80
<SC#-81>    Square/Circle 81
<SC#-82>    Square/Circle 82
<SC#-83>    Square/Circle 83
<SC#-84>    Square/Circle 84
<SC#-85>    Square/Circle 85
<SC#-86>    Square/Circle 86
<SC#-87>    Square/Circle 87
<SC#-88>    Square/Circle 88
<SC#-89>    Square/Circle 89
<SC#-90>    Square/Circle 90
<SC#-91>    Square/Circle 91
<SC#-92>    Square/Circle 92
<SC#-93>    Square/Circle 93
<SC#-94>    Square/Circle 94
<SC#-95>    Square/Circle 95
<SC#-96>    Square/Circle 96
<SC#-97>    Square/Circle 97
<SC#-98>    Square/Circle 98
<SC#-99>    Square/Circle 99
<SC#P-1>    Square/Circle 1
<SC#P-2>    Square/Circle 2
<SC#P-3>    Square/Circle 3
<SC#P-4>    Square/Circle 4
<SC#P-5>    Square/Circle 5
<SC#P-6>    Square/Circle 6
<SC#P-7>    Square/Circle 7
<SC#P-8>    Square/Circle 8
<SC#P-9>    Square/Circle 9
<SC#P-10>    Square/Circle 10
<SC#P-11>    Square/Circle 11
<SC#P-12>    Square/Circle 12
<SC#P-13>    Square/Circle 13
<SC#P-14>    Square/Circle 14
<SC#P-15>    Square/Circle 15
<SC#P-16>    Square/Circle 16
<SC#P-17>    Square/Circle 17
<SC#P-18>    Square/Circle 18
<SC#P-19>    Square/Circle 19
<SC#P-20>    Square/Circle 20
<SC#P-21>    Square/Circle 21
<SC#P-22>    Square/Circle 22
<SC#P-23>    Square/Circle 23
<SC#P-24>    Square/Circle 24
<SC#P-25>    Square/Circle 25
<SC#P-26>    Square/Circle 26
<SC#P-27>    Square/Circle 27
<SC#P-28>    Square/Circle 28
<SC#P-29>    Square/Circle 29
<SC#P-30>    Square/Circle 30
<SC#P-31>    Square/Circle 31
<SC#P-32>    Square/Circle 32
<SC#P-33>    Square/Circle 33
<SC#P-34>    Square/Circle 34
<SC#P-35>    Square/Circle 35
<SC#P-36>    Square/Circle 36
<SC#P-37>    Square/Circle 37
<SC#P-38>    Square/Circle 38
<SC#P-39>    Square/Circle 39
<SC#P-40>    Square/Circle 40
<SC#P-41>    Square/Circle 41
<SC#P-42>    Square/Circle 42
<SC#P-43>    Square/Circle 43
<SC#P-44>    Square/Circle 44
<SC#P-45>    Square/Circle 45
<SC#P-46>    Square/Circle 46
<SC#P-47>    Square/Circle 47
<SC#P-48>    Square/Circle 48
<SC#P-49>    Square/Circle 49
<SC#P-50>    Square/Circle 50
<SC#P-51>    Square/Circle 51
<SC#P-52>    Square/Circle 52
<SC#P-53>    Square/Circle 53
<SC#P-54>    Square/Circle 54
<SC#P-55>    Square/Circle 55
<SC#P-56>    Square/Circle 56
<SC#P-57>    Square/Circle 57
<SC#P-58>    Square/Circle 58
<SC#P-59>    Square/Circle 59
<SC#P-60>    Square/Circle 60
<SC#P-61>    Square/Circle 61
<SC#P-62>    Square/Circle 62
<SC#P-63>    Square/Circle 63
<SC#P-64>    Square/Circle 64
<SC#P-65>    Square/Circle 65
<SC#P-66>    Square/Circle 66
<SC#P-67>    Square/Circle 67
<SC#P-68>    Square/Circle 68
<SC#P-69>    Square/Circle 69
<SC#P-70>    Square/Circle 70
<SC#P-71>    Square/Circle 71
<SC#P-72>    Square/Circle 72
<SC#P-73>    Square/Circle 73
<SC#P-74>    Square/Circle 74
<SC#P-75>    Square/Circle 75
<SC#P-76>    Square/Circle 76
<SC#P-77>    Square/Circle 77
<SC#P-78>    Square/Circle 78
<SC#P-79>    Square/Circle 79
<SC#P-80>    Square/Circle 80
<SC#P-81>    Square/Circle 81
<SC#P-82>    Square/Circle 82
<SC#P-83>    Square/Circle 83
<SC#P-84>    Square/Circle 84
<SC#P-85>    Square/Circle 85
<SC#P-86>    Square/Circle 86
<SC#P-87>    Square/Circle 87
<SC#P-88>    Square/Circle 88
<SC#P-89>    Square/Circle 89
<SC#P-90>    Square/Circle 90
<SC#P-91>    Square/Circle 91
<SC#P-92>    Square/Circle 92
<SC#P-93>    Square/Circle 93
<SC#P-94>    Square/Circle 94
<SC#P-95>    Square/Circle 95
<SC#P-96>    Square/Circle 96
<SC#P-97>    Square/Circle 97
<SC#P-98>    Square/Circle 98
<SC#P-99>    Square/Circle 99
<C#-1>    Circle 1
<C#-2>    Circle 2
<C#-3>    Circle 3
<C#-4>    Circle 4
<C#-5>    Circle 5
<C#-6>    Circle 6
<C#-7>    Circle 7
<C#-8>    Circle 8
<C#-9>    Circle 9
<C#-10>    Circle 10
<C#-11>    Circle 11
<C#-12>    Circle 12
<C#-13>    Circle 13
<C#-14>    Circle 14
<C#-15>    Circle 15
<C#-16>    Circle 16
<C#-17>    Circle 17
<C#-18>    Circle 18
<C#-19>    Circle 19
<C#-20>    Circle 20
<C#-21>    Circle 21
<C#-22>    Circle 22
<C#-23>    Circle 23
<C#-24>    Circle 24
<C#-25>    Circle 25
<C#-26>    Circle 26
<C#-27>    Circle 27
<C#-28>    Circle 28
<C#-29>    Circle 29
<C#-30>    Circle 30
<C#-31>    Circle 31
<C#-32>    Circle 32
<C#-33>    Circle 33
<C#-34>    Circle 34
<C#-35>    Circle 35
<C#-36>    Circle 36
<C#-37>    Circle 37
<C#-38>    Circle 38
<C#-39>    Circle 39
<C#-40>    Circle 40
<C#-41>    Circle 41
<C#-42>    Circle 42
<C#-43>    Circle 43
<C#-44>    Circle 44
<C#-45>    Circle 45
<C#-46>    Circle 46
<C#-47>    Circle 47
<C#-48>    Circle 48
<C#-49>    Circle 49
<C#-50>    Circle 50
<C#-51>    Circle 51
<C#-52>    Circle 52
<C#-53>    Circle 53
<C#-54>    Circle 54
<C#-55>    Circle 55
<C#-56>    Circle 56
<C#-57>    Circle 57
<C#-58>    Circle 58
<C#-59>    Circle 59
<C#-60>    Circle 60
<C#-61>    Circle 61
<C#-62>    Circle 62
<C#-63>    Circle 63
<C#-64>    Circle 64
<C#-65>    Circle 65
<C#-66>    Circle 66
<C#-67>    Circle 67
<C#-68>    Circle 68
<C#-69>    Circle 69
<C#-70>    Circle 70
<C#-71>    Circle 71
<C#-72>    Circle 72
<C#-73>    Circle 73
<C#-74>    Circle 74
<C#-75>    Circle 75
<C#-76>    Circle 76
<C#-77>    Circle 77
<C#-78>    Circle 78
<C#-79>    Circle 79
<C#-80>    Circle 80
<C#-81>    Circle 81
<C#-82>    Circle 82
<C#-83>    Circle 83
<C#-84>    Circle 84
<C#-85>    Circle 85
<C#-86>    Circle 86
<C#-87>    Circle 87
<C#-88>    Circle 88
<C#-89>    Circle 89
<C#-90>    Circle 90
<C#-91>    Circle 91
<C#-92>    Circle 92
<C#-93>    Circle 93
<C#-94>    Circle 94
<C#-95>    Circle 95
<C#-96>    Circle 96
<C#-97>    Circle 97
<C#-98>    Circle 98
<C#-99>    Circle 99
<C#P-1>    Circle 1
<C#P-2>    Circle 2
<C#P-3>    Circle 3
<C#P-4>    Circle 4
<C#P-5>    Circle 5
<C#P-6>    Circle 6
<C#P-7>    Circle 7
<C#P-8>    Circle 8
<C#P-9>    Circle 9
<C#P-10>    Circle 10
<C#P-11>    Circle 11
<C#P-12>    Circle 12
<C#P-13>    Circle 13
<C#P-14>    Circle 14
<C#P-15>    Circle 15
<C#P-16>    Circle 16
<C#P-17>    Circle 17
<C#P-18>    Circle 18
<C#P-19>    Circle 19
<C#P-20>    Circle 20
<C#P-21>    Circle 21
<C#P-22>    Circle 22
<C#P-23>    Circle 23
<C#P-24>    Circle 24
<C#P-25>    Circle 25
<C#P-26>    Circle 26
<C#P-27>    Circle 27
<C#P-28>    Circle 28
<C#P-29>    Circle 29
<C#P-30>    Circle 30
<C#P-31>    Circle 31
<C#P-32>    Circle 32
<C#P-33>    Circle 33
<C#P-34>    Circle 34
<C#P-35>    Circle 35
<C#P-36>    Circle 36
<C#P-37>    Circle 37
<C#P-38>    Circle 38
<C#P-39>    Circle 39
<C#P-40>    Circle 40
<C#P-41>    Circle 41
<C#P-42>    Circle 42
<C#P-43>    Circle 43
<C#P-44>    Circle 44
<C#P-45>    Circle 45
<C#P-46>    Circle 46
<C#P-47>    Circle 47
<C#P-48>    Circle 48
<C#P-49>    Circle 49
<C#P-50>    Circle 50
<C#P-51>    Circle 51
<C#P-52>    Circle 52
<C#P-53>    Circle 53
<C#P-54>    Circle 54
<C#P-55>    Circle 55
<C#P-56>    Circle 56
<C#P-57>    Circle 57
<C#P-58>    Circle 58
<C#P-59>    Circle 59
<C#P-60>    Circle 60
<C#P-61>    Circle 61
<C#P-62>    Circle 62
<C#P-63>    Circle 63
<C#P-64>    Circle 64
<C#P-65>    Circle 65
<C#P-66>    Circle 66
<C#P-67>    Circle 67
<C#P-68>    Circle 68
<C#P-69>    Circle 69
<C#P-70>    Circle 70
<C#P-71>    Circle 71
<C#P-72>    Circle 72
<C#P-73>    Circle 73
<C#P-74>    Circle 74
<C#P-75>    Circle 75
<C#P-76>    Circle 76
<C#P-77>    Circle 77
<C#P-78>    Circle 78
<C#P-79>    Circle 79
<C#P-80>    Circle 80
<C#P-81>    Circle 81
<C#P-82>    Circle 82
<C#P-83>    Circle 83
<C#P-84>    Circle 84
<C#P-85>    Circle 85
<C#P-86>    Circle 86
<C#P-87>    Circle 87
<C#P-88>    Circle 88
<C#P-89>    Circle 89
<C#P-90>    Circle 90
<C#P-91>    Circle 91
<C#P-92>    Circle 92
<C#P-93>    Circle 93
<C#P-94>    Circle 94
<C#P-95>    Circle 95
<C#P-96>    Circle 96
<C#P-97>    Circle 97
<C#P-98>    Circle 98
<C#P-99>    Circle 99
<SL-A>    Square A
<SL-B>    Square B
<SL-C>    Square C
<SL-D>    Square D
<SL-E>    Square E
<SL-F>    Square F
<SL-G>    Square G
<SL-H>    Square H
<SL-I>    Square I
<SL-J>    Square J
<SL-K>    Square K
<SL-L>    Square L
<SL-M>    Square M
<SL-N>    Square N
<SL-O>    Square O
<SL-P>    Square P
<SL-Q>    Square Q
<SL-R>    Square R
<SL-S>    Square S
<SL-T>    Square T
<SL-U>    Square U
<SL-V>    Square V
<SL-W>    Square W
<SL-X>    Square X
<SL-Y>    Square Y
<SL-Z>    Square Z
<SLP-A>    Square A
<SLP-B>    Square B
<SLP-C>    Square C
<SLP-D>    Square D
<SLP-E>    Square E
<SLP-F>    Square F
<SLP-G>    Square G
<SLP-H>    Square H
<SLP-I>    Square I
<SLP-J>    Square J
<SLP-K>    Square K
<SLP-L>    Square L
<SLP-M>    Square M
<SLP-N>    Square N
<SLP-O>    Square O
<SLP-P>    Square P
<SLP-Q>    Square Q
<SLP-R>    Square R
<SLP-S>    Square S
<SLP-T>    Square T
<SLP-U>    Square U
<SLP-V>    Square V
<SLP-W>    Square W
<SLP-X>    Square X
<SLP-Y>    Square Y
<SLP-Z>    Square Z
<TL-A>    Triangle A
<TL-B>    Triangle B
<TL-C>    Triangle C
<TL-D>    Triangle D
<TL-E>    Triangle E
<TL-F>    Triangle F
<TL-G>    Triangle G
<TL-H>    Triangle H
<TL-I>    Triangle I
<TL-J>    Triangle J
<TL-K>    Triangle K
<TL-L>    Triangle L
<TL-M>    Triangle M
<TL-N>    Triangle N
<TL-O>    Triangle O
<TL-P>    Triangle P
<TL-Q>    Triangle Q
<TL-R>    Triangle R
<TL-S>    Triangle S
<TL-T>    Triangle T
<TL-U>    Triangle U
<TL-V>    Triangle V
<TL-W>    Triangle W
<TL-X>    Triangle X
<TL-Y>    Triangle Y
<TL-Z>    Triangle Z
<TLP-A>    Triangle A
<TLP-B>    Triangle B
<TLP-C>    Triangle C
<TLP-D>    Triangle D
<TLP-E>    Triangle E
<TLP-F>    Triangle F
<TLP-G>    Triangle G
<TLP-H>    Triangle H
<TLP-I>    Triangle I
<TLP-J>    Triangle J
<TLP-K>    Triangle K
<TLP-L>    Triangle L
<TLP-M>    Triangle M
<TLP-N>    Triangle N
<TLP-O>    Triangle O
<TLP-P>    Triangle P
<TLP-Q>    Triangle Q
<TLP-R>    Triangle R
<TLP-S>    Triangle S
<TLP-T>    Triangle T
<TLP-U>    Triangle U
<TLP-V>    Triangle V
<TLP-W>    Triangle W
<TLP-X>    Triangle X
<TLP-Y>    Triangle Y
<TLP-Z>    Triangle Z
<SCL-A>    Square/Circle A
<SCL-B>    Square/Circle B
<SCL-C>    Square/Circle C
<SCL-D>    Square/Circle D
<SCL-E>    Square/Circle E
<SCL-F>    Square/Circle F
<SCL-G>    Square/Circle G
<SCL-H>    Square/Circle H
<SCL-I>    Square/Circle I
<SCL-J>    Square/Circle J
<SCL-K>    Square/Circle K
<SCL-L>    Square/Circle L
<SCL-M>    Square/Circle M
<SCL-N>    Square/Circle N
<SCL-O>    Square/Circle O
<SCL-P>    Square/Circle P
<SCL-Q>    Square/Circle Q
<SCL-R>    Square/Circle R
<SCL-S>    Square/Circle S
<SCL-T>    Square/Circle T
<SCL-U>    Square/Circle U
<SCL-V>    Square/Circle V
<SCL-W>    Square/Circle W
<SCL-X>    Square/Circle X
<SCL-Y>    Square/Circle Y
<SCL-Z>    Square/Circle Z
<SCLP-A>    Square/Circle A
<SCLP-B>    Square/Circle B
<SCLP-C>    Square/Circle C
<SCLP-D>    Square/Circle D
<SCLP-E>    Square/Circle E
<SCLP-F>    Square/Circle F
<SCLP-G>    Square/Circle G
<SCLP-H>    Square/Circle H
<SCLP-I>    Square/Circle I
<SCLP-J>    Square/Circle J
<SCLP-K>    Square/Circle K
<SCLP-L>    Square/Circle L
<SCLP-M>    Square/Circle M
<SCLP-N>    Square/Circle N
<SCLP-O>    Square/Circle O
<SCLP-P>    Square/Circle P
<SCLP-Q>    Square/Circle Q
<SCLP-R>    Square/Circle R
<SCLP-S>    Square/Circle S
<SCLP-T>    Square/Circle T
<SCLP-U>    Square/Circle U
<SCLP-V>    Square/Circle V
<SCLP-W>    Square/Circle W
<SCLP-X>    Square/Circle X
<SCLP-Y>    Square/Circle Y
<SCLP-Z>    Square/Circle Z
<CL-A>    Circle A
<CL-B>    Circle B
<CL-C>    Circle C
<CL-D>    Circle D
<CL-E>    Circle E
<CL-F>    Circle F
<CL-G>    Circle G
<CL-H>    Circle H
<CL-I>    Circle I
<CL-J>    Circle J
<CL-K>    Circle K
<CL-L>    Circle L
<CL-M>    Circle M
<CL-N>    Circle N
<CL-O>    Circle O
<CL-P>    Circle P
<CL-Q>    Circle Q
<CL-R>    Circle R
<CL-S>    Circle S
<CL-T>    Circle T
<CL-U>    Circle U
<CL-V>    Circle V
<CL-W>    Circle W
<CL-X>    Circle X
<CL-Y>    Circle Y
<CL-Z>    Circle Z
<CLP-A>    Circle A
<CLP-B>    Circle B
<CLP-C>    Circle C
<CLP-D>    Circle D
<CLP-E>    Circle E
<CLP-F>    Circle F
<CLP-G>    Circle G
<CLP-H>    Circle H
<CLP-I>    Circle I
<CLP-J>    Circle J
<CLP-K>    Circle K
<CLP-L>    Circle L
<CLP-M>    Circle M
<CLP-N>    Circle N
<CLP-O>    Circle O
<CLP-P>    Circle P
<CLP-Q>    Circle Q
<CLP-R>    Circle R
<CLP-S>    Circle S
<CLP-T>    Circle T
<CLP-U>    Circle U
<CLP-V>    Circle V
<CLP-W>    Circle W
<CLP-X>    Circle X
<CLP-Y>    Circle Y
<CLP-Z>    Circle Z
-handleman, CSWP (The new, easy test)
wow, thats alot!
Thanks handleman
alt+0176 = °
alt+0177 = ±
alt+0216 = Ø
remember you need to use number pad
