Diesel Injector Driver (CRD)
Does anyone know of a source for a Injector Driver Box that will drive common rail injectors (Bosch, Delphi, Siemens)? I am looking for a reasonably priced driver that will work in a vehicle for a personal project. I know there are lab grade units that cost thousands, I am looking to spend hundreds. I would happy if it can drive 4 injectors at the required P&H. I want to fire the injector using the ignition output (TTL) of an automotive type module.
RE: Diesel Injector Driver (CRD)
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Delphi supplied control modules to, I believe, Renault in Europe for common rail applications.
These modules were also used by Ford of Europe on common-rail engines where the Ford/Visteon ECU was used to do all the control work and the Delphi module was used to handle the injector control.
A Delphi part number like 593 062 24, or 593 050 62 would be such a part.
A Ford Finis code of 1216024 equates to the second Delphi number.
No idea how you'd get the info for programming and the module pin-out though.
Bill
http://www.bgsoflex.com/megasquirt.html
It is worth a shot.
