Servo press Brands
Servo press Brands
Servo press Brands
Hi
  Can you suggest some servo press brands?
Application:
   press an 8mm three legged flag type Terminal into the printed circuit board (PCB)
Requirements
1.-Range Force  0-3 kN.
2.-Stroke 300 mm
3.-Speed 200 mm/sec
4.-Voltage supply: 480 VAC
5.-Force Distance Control (Load Cell & LVDT)
          5.1   Precise positioning control +- 0.01mm.
          5.2   AccurateForce Transducer system (+- 0.5% of nominal force range).
6.-Integrated Anti-rotation.
7.-Integrated Holding/Safety Brake.
5.-Servo Amplifier Data bus: Rs-232|Ethernet
Thanks in advance.
