battery clamp
battery clamp
battery clamp
Hey
I am not good at GSD so, Could you give me some advise how to start drawing battery clamp.
Regasrds
Santa123
RE: battery clamp
my advice is to model it with the Part Design workbench.
is there a particular need for surface geometry?
RE: battery clamp
yes, I need unfold this clamp
RE: battery clamp
to unfold it, my advice is to use the Sheetmetal workbench - probably Aero Sheetmetal for the flange that goes around the hub.
another method is to model it with Part Design, and then extract the surface. offset the surface to the neutral plane, and use the Developed Shapes tool to unfold it.
either way, you'll only get an approximate solution due to the stretching the material.
RE: battery clamp
to be honest, I do not know how to join the hub and connector and how to draw the elongated hole.
RE: battery clamp
That's why is good to take some classes....for the sheetmetal workbench you will not find so easy free tutorials (video or something else..).
Its not a difficult workbench but you will learn faster and better.
Fernando
