Missing Window
Missing Window
After a crash, SolidEdge v18 now refuses to show the window that displays after you use the inspect menu to measure distance, angle etc...
I have tried re-installing and the latest SP but nothing can get the window back.
Anyone had this before?
RE: Missing Window
usually deinstall/reinstall will leave the registry untouched
and thus everything is unchanged. To get the window back
you can try to delete this key (only this) SE must not be active:
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version xx\Part\MeasureDlg
xx = your SE version. If that does not help you can delete the
whole key:
thereby loosing all your settings. SE will recreate the key upon
start.
HTH
dy
RE: Missing Window
Your're a star :)
RE: Missing Window
thanks for the kudos. Now that all is working as it should
it's time to export the whole registry key
to a save place. When later on something is wrong you can
delete the key and restore it by double clicking on
the saved .reg file
dy
