Animating an Assembly in PROE Wildfire 3
Hi everyone!
Hoping an animation guru can help me out - I am trying to animate an assembly sequence. I've been able to do it just a few days ago ( I have a video file of it) but for some reason, using the same model, even the same file, I cannot seem to move parts around to create Key Frame Sequence shots.
I check out the model into my workspace, assemble it into a new file, go to animation - bodies - one part per body - key frame sequence - snapshot - drag body and click on the model to move a bolt, nut, part etc. i can see the cursor and coordinate position move, but the part itself will not. Is there some constraint I have left out? I don't see any under the constraints tab.
Any help i can get will be appreciated. It is quite frustrating!
