Quick CNC question about M08 code...
On a machining center typically, when do you turn on / off the coolant pump? Does it need to be off before reaching the tool changer, on before leaving it?
Any suggestions / methods are appreciated. thanks.
RE: Quick CNC question about M08 code...
Larry
Larry Coyle
Managing Partner
Cylinder Head Engineering, LLC
CNC Porting
De Soto, KS 66018
turning the pump on and off
advantages = less foam in the tank - more quiescent time for fines to settle or be filtered
disadvantages + there may be a lag in time between when the machine starts to cut and the fluid reaches the point of cut leading to tool failure from thermal shocking -- more wear and tear on the coolant pump etc.
shutting off fluid flow with a valve
advantage = fluid is instantly available - less chance of air being captured in the coolant delivery system
disadvantage = dead heading the pump can cause foam in the tank == can raise the operating temperature of the working solution can be hard on rotary unions and seals
A.R. "Andy" Nelson
Engineering Consultant
anelson@arnengineering.com
Most normally you turn it off before the G91G28Z0 move.
Some do this right after the cuts finished.
G1Z2.F100.M8;
G91G28Z0;
G91G28X0Y0;
Tool change or M30
and on and on
Jamey
Visit www.cncalarms.com for CNC related alarms and to lookup troubleshooting tips.
Most posts can be developed to deal with this issue. Coolant foam is more an issue of an anti-foaming agent in the coolant itself.
