RMB-Mass Properties Info
Tell me if you like this idea and I'll submit an enhancement request. See attachment. I think it's kinda cool? Or maybe it's already in the software and I don't know about it.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 3.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: RMB-Mass Properties Info
It sort of is already in the software.  If you select a part or subassembly from the feature tree prior to Mass Properties, or change selections while Mass Properties window is visible, you can get component mass properties directly from/in context of the assembly.
-handleman, CSWP (The new, easy test)
You can set a keyboard shortcut to activate the Mass Properties.
Having an RMB pick would be another good option though.
Son of a gun......Never knew that option was available. As they say.....learn something new everyday.
Mechanical Designer
thanks for making feel good guys.
Hey, how about when you hover over the assembly or part? huh? It kind of does it now showing the configuration state.
Mechanical Designer
