OLE issues
OLE issues
I have an issue on my machine that I am unable to insert a Design table into my part. I read through the knowledge base and if you cannot place an Excel table into Word Pad then you have an OLE issue and repairing MS office will fix this issue.
I could not repair the install it continued to fail. I ended up reinstalling MS office 2007, however the problem still exists. I have not been able to find a solution on the web and I am curious if anyone else has seen this and found a solution for it?
It was working at one time, but in recent weeks it completely stopped.
Vista 64-bit
MS Office 2007
Vista 64-bit
MS Office 2007
Scott Baugh, CSWP ![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: OLE issues
"If you use design tables and/or BOMs a lot, check your task manager processes (not just applications) for an Excel process running in the background when the Excel window is closed."
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
