reinforced concrete diaphram wall between concrete filled pipe piles
I want to install a 5m reinforced concrete diaphram wall between concrete filled pipe piles on a bridge pier. Looking for some reference material or has anyone complete a similar design. I've sized the reinforcement for moment and shear due to lateral loading on the bent. Trying to determine the best way to attach the wall to the pipe (i.e. run reinforcment through holes cut in piles, etc...)
RE: reinforced concrete diaphram wall between concrete filled pipe piles
