Problem with Patran/Nastran
Hi there
I'm running a chassis analysis on Patran-Nastran, but there is a problem when I'm trying to visualize the results. I don't know why, but after Nastran runs the study, there is no file created.
Can you help me?
Thanks a lot
Can you help me?
Thanks a lot
RE: Problem with Patran/Nastran
Are you sure you are looking in the right folder? Usually, Patran (and nastran if you run it directly from Patran) creates the result file in the same folder as Patranwas started from. It might be a different folder that where the database is.
Im running Patran/Nastran 2005
http://www
I have tried to solve the problem following that link, but I havent found the solution.
I have downloaded a new version of the analysis.exe file. Now, when I run an analysis, if I open the log file there is no error. But there is no results and no xdb file created.
what is write in the f06?
there is any fatal error?
I suggest to run a test file in the scratch directory.
You can pick the test file .../nast/demo/d10101d.dat and copy it in the scratch directory, then run directly nastran looking for d10101d.dat.
in this way you are sure that the nastran deck file is correct and see if the problem is in the license or in the executable.
In which case nothing will solve until you install the patch to fix the bug.
Cheers
