Overpressure Crankcase
I'm running three deutz gas engine with demand load of 1.845MW,one of the which is biggest 1.5MW suddenly drop on load due to overpressure crankcase.What might leads to this problem?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Overpressure Crankcase
A compression check should pinpoint the bad one. A thermal scan of the exhaust manifold would also quickly point out the cool cylinder(s).
Keith Cress
Is the engine fitted with anti-knock (AKR)? Did this show any fault?
If someone has reset the fault, then the history log will be overwriting earlier data, the maximum storage is 40 hours......
Then boroscope the suspect cylinder (or all of them if the data is lost). Do not run the engine until you have done this.
Iagree with the others, looks like piston / rings.
