CV control valve
CV control valve
How can I figure out the flow coefficient CV under certain conditions?
The fluid is a gas.
Data available are: mass flowrate, inlet pressure, pressure drop, inlet temperature, vapour molecular weight,
compressibility factor, viscosity at inlet temperature and specific heat ratio.
I need to figure out it for a control valve with non-critical flow (dp<0.5p1).
Is it the same for any other type of valve?
Thanks.
The fluid is a gas.
Thanks.
RE: CV control valve
1. You ask the supplier or go to the link below.
2. Not the same, see link below.
ht
Download the Control Valve Handbook. This includes the formula for sizing control valves in gas service and more. Contact your control valve peddler and request a sizing program.
