Steel Tube for ATV frame
I am currently looking to design and build my own ATV/quad frame. However I don't know what material to use. Could someone please advise me what materials of steel are best suited to this type of application.
RE: Steel Tube for ATV frame
The bigger Diameter of tubing will give higher strength, adn if designed properly you should be able to optimize for both strength and weight by adjusting diameter and wall thickness.
Nick
