Solidworks to DWG, Blocks copy each other in AutoCad
My customer needs to have all his files in DWG and saved out to one DWG file. I batch convert all my Solidworks drawings to DWG and then macro a copy / paste to the master DWG file. Problem is that the hole chart becomes a block and assumes the properties of the 1st block inported into AutoCad. Every time I copy and paste a new drawing into AutoCad the hole chart changes. The blocks have the same name.
I have not found a way inside Soildworks to not give this block a name. I could macro my way out of this..but is there anything I can do inside Solidworks?
Solidworks 2009 SP3.0
Computer: commodore 64 / .1 megs of ram
RE: Solidworks to DWG, Blocks copy each other in AutoCad
Yes, do everything in SW and trash ACAD.
You will not have a clean transfer of all data from SW to ACAD. Try saving the SW drawing as DXF then import into ACAD and save as DWG.
I refuse to use both apps together, it's more work than needed.
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
