Nitrogen blanketing of Canola Oil tanks
We are looking at adding a Nitrogen blanketing system to our refined oil tank farm. We have 11 tanks varying in size from 90000 to 1300000 Litres. Total capacity of 3500000L. Our maximum oil flow out is 850L/min. I would like to connect all the tanks to one common pipe/header with one pressure vacuum relief valve and a blanketing flow valve inside the refinery building to prevent icing in the Winter. Is this a reasonable way to do it?
thanks
RE: Nitrogen blanketing of Canola Oil tanks
Are going to be pumping in and out of the tanks in the same proportion of flowrate to surface area of the tank contents?  My guess is that you are NOT.  It would be a controls nightmare.  If you don't then you will have variable rates at which you will need to add or vent blamket nitrogen.  The purpose for inerting canola is to prevent oxidation and souring of the oil.  If you use a common blanket valve and relief valve, you will have an imbalance and likely draw in air (with oxygen).  So, I sugget you look at dedicated valves for each tank.
I can't see any reason why this would not work.  I would have a self regulating PCV on the upstream which would open when the header pressure falls and another downstream to open when header pressure rises.
In my mind this arrangement (assuming sizing has been carried out correctly) would present no problems.
Your design sounds OK. That is the way diluted bitumen tanks were blanketed. They fed our oil sands upgrader. You should check to see how they do it now.
HAZOP at www.curryhydrocarbons.ca
I'd install a separate n2-header appart from the relief header for safety. Keep a bit of oversize on the relief header. Also it's easier to abate oxygene when n2 comes in through the tank instead of the same way oxygene might have come. Your choice of one pvrv on a header sounds propper for a nonflamabil, youre only protecting for tank rupture. However, no possibility of isolating individual tanks from your pvrv header (blinding flanges, checkvalves, valves) should be allowed. Also be aware of the danger of nitrogen leakage into enclosed spaces from a pvrv (you mentioned refinery BUILDING), take care of propper ventilation and o2 concentration alarms in concerned working environment.
I just finished training at Fisher Regulators in Texas and had a short course on tank blanketing.  Nowhere did they even mention or recommend a single header to control a bunch of tanks.  I think the reason is that the blanketing pressure is so low that it would be almost impossible to control.  Plus, if you make the pressure higher, the use of N2 will increase, costing more in the long run.
I tried to upload the brochure for you to look at, but the program gave me errors.  You can look at the link below for more information.
To all,
I think that risk of equipment failure and the resulting consequences are another factor to be considered. Spending a little more sometimes can purchase peace of mind.
While you might save a few dollars in capital equipment costs, you may put a very large volume of oil at risk of spoilage should something fail and the failure is not discovered quickly.
-MJC
Personally, I think it is a bad idea.  Eleven tanks to a common PVVV is a vacuum collapse waiting to happen.  You probably only have a 0.25 - 0.5 psi vacuum rating.
If this is carried out consider draindown with pumpout for your blanketing requirement. Also the need to have isolation valving or line-blanking capability at every vessel to allow confined space entry.
I've had a good bit of headache out of our venting system, and unforuantly it is very similar to what you describe.
In order to save money, we had installed one single nitrogen blanketing valve which was connected to a header of 1" pipes which were connected to every tank. If a low pressure event occured within a tank, there is no way the blanketing valve could respond in time.
Since then, I've went back and installed an individual valve on several of our bulk storage tanks. It was pricey, around $3000 per Fisher ACE95 valve. Each tank that received a valve was modified with a pair of 1" 150# flanges at 90 degrees apart on the tank. The first for the valve, the second for the sense line.
We also had to button our system up better. This required replacing a homemade manway on one bulk storage tank with a flanged emergency relieving manway. It was a ValveConcepts manway, around $5000 for the manway and the 16"? flange addition to the tank.
Our header system is 2" pipe. The line has many twist, turns, low spots. At the end of the line it goes though a condenser and then vents though a conservation vent. I'd much rather have a single straight 4" line with just a couple of branches that drop off to pick up a couple of the tanks than our current arrangement. But that is for the future.
As for the freezing problem, look at purchasing a refrigerated air dryer. $2500 or so, and have some good filters in line to pull out any condensed moisture or oil.
Also I assume you are generating your nitrogen. We have an OnSite nitrogen generator that works wonders, but you have to keep good, clean air supplied to it.
Put some thought into your system to avoid the headaches that will come later down the road. But for sure, put an individual blanket valve on each tank. Use short straight runs of pipe for your header system. Clean up your air supply to prevent freezing.
Oh also, get your hands on a copy of API 2000. It will walk you though the flow rates needed for pump down and tank breathing.
You do not want to use a single regulator to blanket multiple tanks, bad, bad, bad idea.
You can quickly see this working out the hydraulics trying to flow a volume of blanket gas at inches of water to replace either thermal inbreathing or pump out rates to the tank at the end of the line.
Regulators are relatively cheap, provide one at each tank.  I just looked at tank where the client sized the regulator correctly and then mounted the regulator a couple of hundred feet from the tank and ran a 1" line to the tank, same as the supply line.  They couldn't figure out why the regulator didn't seem to keep pressure on the tank till I showed them the pressure drops needed.
I am surprised you don't have each tank protected from pressure/vacuum by its own "pallet" based PSV. For my money think of nitrogen blanketing and hi/lo pressure protection as two distinct things.
Seems from what I've read that I'll be looking at Multiple Blanketing Valves and PRV's. I got a copy of a system from one of our plants and they put in a blanketing valve, pressure/vacuum relief valve and an Emergency pressure/vacuum relief valve in each tank. I s this common practice to have two relief valves?
<I s this common practice to have two relief valves?  >
yes.  The valve for normal operations is much too small for emergency venting, but suffices for tank filling/emptying and diurnal breathing.  In the event of an external fire or other incident that will put a lot more heat into the oil, or a broken pipe, or whatever other cause of major discharge you can think of, you will need a larger relief device to prevent tank rupture.
