Design of L & T shaped column.
hi to all
can anybody help me for design procedure of L& T shaped
column.
column.
RE: Design of L & T shaped column.
If this is the case, check out ASD Manual of Steel Construction, 9th Ed., Chapter 3. Pages 3-55 to 3-58 contain design examples for angle columns. Load charts for Double Angles and Structural Tees (WT sections) follow this.
Msachine - do you mean concrete columns?
PCA Column program does the job for you. It has very good GUI and capacity to design any arbtrary shaped column.
If you are looking for theory, the belive it would be similar to that of rectangular columns with little more involved calculations, but not very sure.
Bannu
design procedure for same.
with regards,
msachine.
i have the version 2.2 of that program (1989) nd i want n new version of that program if it possible
