Operating & Control
Operating & Control
Operating & Control
Hi all,
Whats "operating and Control philosophy" documents on sales gas project or in general must describe?
I appreciate your thoughts.
RE: Operating & Control
From www.urswriter.com
Control & Operability Philosophy
This document should describe the general principles that the end user will want to apply to the project.
It should define in principle the level of process automation that is required, the information handing needs and the operational requirements.
Typical issues are:
What level of flexibility is required?  The plant may be dedicated to a single product and always use the same recipe.  Or the plant may be intended to make a large range of products. These issues can influence the requirements' analysis considerably.
How far up the procedural model should the automation extend?  For example, some operators want phases automated but operations and procedures to be manual.
What level of manual control intervention is required.
What level of batch reporting and management information will be required?
Who operates the plant?
Where do the operators work?
What skill levels they will have?
