milling the highest possible finish in copper
We're looking to mill the best posible finish in some small parts. The material is OFE CU ASTM F68 CLS 1. (which is basically the finest grade of oxygen free copper). We need at least a 16 rms or better on the floor and walls of a small iregular pocket. We can't use a wiper type tool because of embedded contaminants as these components are part of linear atomic particle accelerator and must function in ultra high vaccuum. Short of a diamond milling machine (which we don't have) our research has led us to some avenues of approach. I am wondering if they are any other suggestions?
thanks
thanks
RE: milling the highest possible finish in copper
Here is a link to information of one fluid that might work well - there are of course others this is just one that I am familiar with
http://ww
A.R. "Andy" Nelson
Engineering Consultant
anelson@arnengineering.com
Fine feed. Super fine feed. Super super fine feed.
Vacuum out the chip continuously.
Small edge radius.
Big, heavy CNC machine.
Stabilize the temperature with a/c and extended run time.
Slow down the axis feeds, and accelerations if you can.
Make parts only in the dead of night, with no other machinery running, and no traffic.
Don't walk, or even talk, near the machine while cutting.
Mike Halloran
Pembroke Pines, FL, USA
On the few occasions I've had to machine copper, I found ordinary lube oil worked fairly well and I've heard that some even older timers than me, swear that milk (I guess the full fat variety) works even better, although it would need a good clean up after to prevent a stink!!
Sabreblue, MQL seems very interesting and you're right, we are very limited in the coolants we can use -no sulfur, no chlorine, no hydrocarbons etc...Right now we are using Trimsol E206 which one of the national labs recommended to us. We have a new Haas VF2 with the air blaster which we might be able to rig up for MQL
Mikehalloran, our pocket floor to wall radius is .000 to .002 max, so a sharp tool is the only way to go. As far as feed is concerned, we are finishing at about .0003 doc @ .0003 ipt. and 420~450 sfpm. We have found that this is nearly the slowest that we can go without burnishing. Vaccuum is a good idea and I have used this method in drilling holes through angled parabolic mirrors, but is also means dry machining which is a little risky for these parts at this time. Interesting also is that we conducted vibrational studies on one of our mills and discovered several frequency zones which produce the most machine movement. We tend to avoid these rpm zones if possible.
SincoTC, I've heard of the milk trick as well. What's more is that I think that I can enlist a squad of local alley cats to clean the machine to maximum cleanliness!
thanks for the feedback!
Mike Halloran
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Scott
www.1helical.com
Scott
www.1helical.com
