Modify Weldment Cut List
Hi all, I'm attempting to create a modified weldment cut list, thus far I've made a copy of the original and added the required columns. The problem is that I don't know how to link the fields in my newly modified WCL to the available tags in the Property Name column in the WCL properties table.
Harry
(great forum by the way)
RE: Modify Weldment Cut List
Hmmmm, OK tried that, no joy. At present in the table there is only the default four columns Item No, Qty, Description and Length which all work fine. I tried adding materials as a property name and re-inserting the Cutlist Table but no Materials column appeared. I hope I've explained it clearly and thanks for your reply too.
regards
Harry
1) Create the weldment
2) Add Properties to the Cut List Items/Folders
3) Create a drawing
4) Add a Cut List table
5) Add a new column
6) Click on the column heading (A, B, C, etc)
7) From the Column Properties manager, select Cut list item property
8) From the drop down list, select the property created in the weldment at step 2.
9) Click the Tick to accept the choice (Cut list should now display the property)
10) RMB > Save as the table to a .sldwldtbt format for future use.
Fantastic, many many thanks for your help.
best regards
Harry
