"fixture transfer failed" error
I changed the material on a part that had previously ran fine. When I ran the analysis, 5 of the six fixtures defined resulted in a "fixture transfer failed" error right out of the box. Any help would be greatly appreciated.
RE: "fixture transfer failed" error
I have had this error before. I believe this happens when you modify a part's properties (geometric or material) but forget to right click on the study and select 'update all components'.
Hope this helps
James
Looks like that was the problem.
