BOM Repeat Region - Advanced Manipulation
I am trying to generate a table illustrating two assemblies side-by-side using the same parts list. i.e. one configuration of the assembly using part A with fasteners, but a different configuration uses part B with all the same fasteners.
My approach so far: I assembled the two assemblies into a top level reference assembly. I then made the table recursive and filtered out both their top levels. Using relations, I'm assigning the report values to parameters, and then reporting those parameters to the table. I have successfully accomplished this (my table is displaying all of the columns I desire), but in my code I am lacking the Pro/E identifier to how it recognizes one "asm.mbr.generic.name" is different from another "asm.mbr.generic.name" to ensure the quantity totals are correct. Can anyone help me??
Here's a quick graphic trying to show what I mean:
1 0 Part A
0 1 Part B
4 4 Bolt
8 8 Washer
4 4 Nut
-001 -003 Part Number
QTY QTY
REQ'D REQ'D
1 0 Part A
0 1 Part B
4 4 Bolt
8 8 Washer
4 4 Nut
QTY QTY
REQ'D REQ'D
