Plates as Slabs
Plates as Slabs
I have a situation where I am trying to model the relative stiffness between a set of beams and a concrete slab. I have an 8" slab drawn as plates and supported on column concrete members.
I know with member design you can control the crack factor of concrete members. I cannot find this for plate members.
Is there anyway to model this reduced stiffness other than reducing material properties?
Thanks!
Thanks!
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
RE: Plates as Slabs
Are you trying to model the concrete plate so that it engages the beams to form composite action? - Maybe try modeling a T-beam with the slab as the flange.
RE: Plates as Slabs
Josh
RE: Plates as Slabs
Thanks for the response.
RC
Edmund Burke
RE: Plates as Slabs
Keep in mind, of course, that the flexural stiffness is proportional to t^3.
Josh
