How to create a concentrated force in the middle of a beam ?
I have a rather simple model : I-Beam constrained at the 2 edges, with a concentrated force acting in the middle of the beam, on the top-surface of the beam.
I draw the beam, but after, to position the load, I need to selection a point which doesn't exist. So I created a "reference point" on my beam, a the place where I want my load to be applied, and I configured the load.
When I submit the job, it is aborted and my errors are :
"Node set assembly__pickedset6 has not been defined
A concentrated load has been specified on node set assembly__pickedset6. This node set is not active in the model
Analysis Input File Processor exited with an error."
What can I do ?
Thank you
What can I do ?
Thank you
RE: How to create a concentrated force in the middle of a beam ?
Rob Stupplebeen
Thanks for your advice !
