Looking for monitored spool position valves
I'm trying to find a hydraulic (and pneumatic) control valve in witch some sort of position sensing (electrical)would indicate the spool position.
I was told that Parker had this kind of valve but was unable to find it.
Real
Real
RE: Looking for monitored spool position valves
Look in Hydraulics & Pneumatics Designers Guide at http://www.fpweb.com under Proportional Valves. They usually have an optional LVDT on the spool or spools to feedback position information to the control card.
Bud Trinkel
fluidpwr@evansville.net
Fluid Power Solutions
33+ years experience in hydraulic and pneumatic circut design, troubleshooting and training.
Parker does have a monitor switch for monitoring the shifted condition of the spool. If you just need to know that the spool has shifted to a certain position, there is a simple on-off switch. If you need more precise feedback, then a proportional valve is more what you need.
For hydraulic applications, you can find the monitor switch on the Parker website, under "hydraulics" and "industrial"
email me if you need more info.
kbresnahan@parker.com
