Attach Surface Finish Symbol?
I've been asked what I thought was a simple question until I had a go myself.
In 2D drawing format, I wish to attach a surface finish symbol to the outside dia of a shaft but show the symbol on the dimension line.
I can attach the symbol to the shaft edge but cannot constrain the symbol on the dimension line? Am I missing something fundamental?
Mechcad8
RE: Attach Surface Finish Symbol?
Please refer the attached picture.
Artem Taturevich
CSWP
The referenced line did not appear for me automatically, I needed to select [Add leader and change the arrow head to no arrow]
I'm sure a default setting could probably change that if it became a regular requirement.
Mechcad8
Mechcad8
-handleman, CSWP (The new, easy test)
Wouldn't an extension line be better?
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
See 8th bulleted item at http://www
