Help in determining airflow
I'm trying to calculate the airflow in a compressed air pipe. I know the pressure reading from the gauge and the pipe diameter. Is there an equation I can use to find the CFM with what I have. I know I can use the equation Airflow = Velocity x Area but I don't know what the velocity is. Is there a relationship between pressure and velocity? Can someone help?
RE: Help in determining airflow
Mike Halloran
Pembroke Pines, FL, USA
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
Fe
