VisMockup Forums?
VisMockup Forums?
Over and above the information provided by Siemens - is there any other TeamCenter Visualization (a.k.a. VisMockup) Forums to be found on the Internet?
RE: VisMockup Forums?
Bob Snead
Designer
Northropgrumman.com
It is also a good way to put geometry in front of engineers and other downstream users who need to quickly examine the data without changing it or perhaps being frequent and skilled users of a more expensive system. Measuring and sectioning work okay and experienced users can easily interact to mark up areas of concern or future changes. Some of the time with faceted models there is some slight inability to closely examine interfaces between freeform shapes but that would be pretty much the only area where there is some slight compromise.
Obviously you can't modify the data but as a visualisation tool or for conduction virtual reviews of large assemblies, quickly finding parts and generally working with models it is pretty good. We've used it in the past for large projects by giving the non-CAD engineers an interface to the data, and by having at least one or two licenses available to the CAD office to quickly open and search the data to discover other possible clashes in the areas adjacent to out components both as an output from teamcentre based global interference checks and in a quick and easy visual sense. Anyone working with really large and complex assemblies is likely to be less effective without it.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
