Patching CAESAR II
Patching CAESAR II
Patching CAESAR II
Can somebody explain me how can I correctly install CAESAR II 5.10 Build 090206?
I have download C2510_090206a.exe from http://www.coade.com/support_downloads.asp?varflag=CAESARII&varreturn=dl
but there is no setup.exe after extracting an archive.
Maybe I can just replace old files in directory C:\Program Files\COADE\CAESAR II 5.10\ with new files?
thank you!
RE: Patching CAESAR II
Sorry for this "half answer", but I'm out of the U.S. right now with limited Internet access.
Unzip the archive you downloaded.  I believe I put a "readme" file there - if so, follow the instructions.  If not, then just copy the files into your \caesar510 program directory (over-writing the existing files).
There is no "setup.exe" because InstallShield went downhill on me and I had to give up on the proper way to distribute a patch.
Richard Ay
COADE, Inc.
Ok, I'll do it! I was just worrying about replacing files in program directory..
Thank you, Richard!
