Bolt Tightening Torque
I need to tight bolt (ASTM A 193 B8) with nut (ASTM A 194 B8).
Can any body help me to provide the torque table for various sizes of bolts of the above material combination.
Moiz Khan
RE: Bolt Tightening Torque
and coating on stud
How long is the grip of the bolt?  Based on that, I could recommend a specific number of turns of the nut.  How much tension do you want to develop?
Why not use a tensioning device such as a Skidmore-Wilhelm gage to determine the proper torque values by testing a sample?
As long as the bolts are in a similar condition, i.e., lubrication, fit of the nut (thread class), etc. you would have a rational basis of the tension to torque values.
Best regards - Al
The matching alloy nut is not the best idea if you ever want to remove it.
You also need to make sure that you develop sufficient assembly load for the gasket.  The B8 bolt you mention (I assume class 1) is a low strength bolt, which will not deliver the necessary minimum gasket assembly stress in many ASME flanges- especially class 150.
