Fall Restraint Beam
Fall Restraint Beam
Existing structure needs a fall restraint beam added. There are 2 rows of several floor openings. There will be 2 fall restraint beams spanning between roof frames. Owner wants 3 people to be able to be tied off each side. I know that the design impact load is 5 kips. Is there a reduction that can be taken for multiple people? Looking at the frame, it seems I should design for worst case 15 kips each side. The probability of 6 people falling at the exact same time cannot be very high. It just seems like overkill.
Any literature on structural design for fall restraint?
RE: Fall Restraint Beam
So, by limiting the lanyard force, you can reduce the required loads. 5.4 kips is much easier to work with than 15 kips.
Joel Berg
Fall Arrest beams are where the lanyard is long enough that the user can fall off the exposed edge.
This is the best demo of the differences I have found:
http://www.latchways.com/default.aspx?item=34
Hopefully that helps.
Joel Berg
That does help! Thank you.
The impact force is modified based on the type of lanyards used so you are usually well under the 5000 lb you mentioned.
