how to measure UHF RFID antenna port impedance
Hi everyone,
How do I measure the complex port impedance of an UHF RFID port antenna? I have tried measuring differential port impedance using VNA with a probe, but the results do not seem to be correct.
RE: how to measure UHF RFID antenna port impedance
"using VNA with a probe" - that doesn't make much sense, can you provide more detail or a photo of your test setup?
What was your test environment?  You can easily get unexpected results by having your antenna too near a metal surface, or more likely not having the same physical ground structure at your test fixture as you have in your application.
Have you verified your test setup by measuring a known impedance?
A crude technique I've used in the past is to use two identical antennas, one as source and one as receptor and then make a couple of S21 measurements with the setup and extract the parameters from there.  If you can get a decent S11 setup you'll probably get much better results though.
John D
In what range of frequency works your RF ID antenna?
Is the setup used by you calibrated somehow? Is there any offsets taken in consideration?
Maybe a picture  would be very helpful for us ,like zappedagain said in the above post.
Mishu
