Mixed Metric Designs
Our electronics company has long designed our products in metric and the mating tooling & fixturing in imperial to continue making use of the in-house machine shop for tooling fabs.
I've recently began designing and submitting tools designed in metric, much to the shop's anger. The company continues to be split about which dimensioning scheme to use. The main argument being the cost of re-tooling the shop to metric "unnecessarily" - "just because the product is in metric doesn't mean the tooling needs to be" they argue.
Their pushbacks have produced several compromise proposals:
1) Don't convert - it's always worked; don't rock the boat.
2) Dual dimension prints; Since the shop (and our auxillary machining vendors) will be converting back to english anyway.
3) Design dimensions in metric, but use english fastening components - english dowel pins & fasteners/tapping.
My responses -
1 & 2 - there's inherent conversion error introduced in switching from one to the other; additionally, since our english unit precision is governed by decimal places, this complicates conversion of tolerances
3 - I don't have a good response to this; just feels wrong to go half-way.
I'd be curious about advice on this battle and input on these objects from those who've gone this road before?
My responses -
RE: Mixed Metric Designs
If you are letting your title block being related to decimal places stop you, frankly that's verging on lazyness. Title block tols are 'unless otherwise stated', i.e. you may have to directly tolerance most dimensions but so be it.
We have a mixture because we use a lot of off the shelf parts that come in a mixture of metric & inch. Recently we've been trying to standardize a bit on metric threaded fasteners, but most drawings are still in inch. If we need to convert we do, if we need all a sig fig we do, if we need to directly tolerance instead of relying on the tol block we do.
There have been quite a few threads about similar, both on this forum and over in I think it was "Mechanical engineering other topics" or maybe something like "Industrial/Mfg engineering other topics". Do a google search of this site using the field at the top.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Measurement systems are arbitary. In the big picture view of the universe, there's no difference between inch or metric. Metric has some advantages in that it easier to think in a metric system (base 10, sizing aligns with mm). But there are some economical advantages to inch in America. There are certainly economical advantages to sticking to one standard, regardless to which one is picked.
Switching is much more complicated that you might be thinking, and the advantage of metric is fairly slight (there are disavantages to a purist metric adoption, as well).
If you are in an Inch environment, just suck it up and do everything in inch, the same if someone who favors inch moves into an metric environment.
I would agree that the swtichover is unnecessary.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Chris
SolidWorks 08, CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Be prepared to discuss the actual costs of switching, including training and potential new hires. Honestly the print is about design intent - you want to put the little squiggles on there that will best represent what you want your design to be - that's why we (here) use black ink on standard sized white paper, with English notes, in imperial units because we know that our suppliers want to see them.
How bad is this problem, really? Can you easily purchase metric components and drills and taps and stuff?
Your machines are indexed in inches and millimeters are they not?
Is this a hardware problem, or is it a machinist problem?
Chris
ctopher's blog
SolidWorks Legion
At the end of the day features that matters say a location pin need to be a certain size it will probably be an odd size in either metric or imperial, features that don't matter should wherever possible be standard sizes and put in to "round figures".
It probably doesn't matter a jot if a support plate is 12mm or ½" or if bolt centres are at 25mm or 1" but it soon becomes a complete mess when you mix them up and costs unnecessary money if you start machining ½" plate down to 12mm, or causes huge problems if you just choose to ignore the odd 0.7mm.
Matt Lorono
Silicon Valley, CA
Look at previous threads above. Take some advise: If the part is designed in metric insist the tooling and manufacturing be in metric. You will regret it if you start mixing the two systems.Just think what some people are asking you to do. Twenty years down the road you would still be working with two systems - just so you can keep a view old machines around.
The people advocating staying with a mixed system will all be retired but your company will still be fighting with all types of conversions - if they are still in business.
Matt Lorono
Silicon Valley, CA
Powerhound, GDTP T-0419
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
And the US President is just some person with an oddly shaped office. :)
I think many Americans might be surprized by the number of countries that ARE NOT 100% metric, many of which are in Europe. :)
Matt Lorono
Silicon Valley, CA
Some areas are more metric than others but it's not across the board. All our new design was metric but interfacing with US equipment or working on older designs we frequently still used inch.
If I understand the OP correctly, I think they may be better sticking with inch for the fixturing drawings. That way the conversion only gets done once and can hopefully be verified. Allowing the default title block tolerance to impede this is ridiculous as far as I can tell.
The end product may be metric but the fixturing doesn't have to be.
KENAT,
Try selecting ball bearings sometime. I have been in a couple of situations where I wanted a bearing slightly smaller than my shaft, and switching units solved the problem.
Here in Canada, we are officially metric, but lots of people do English drawings. When I send out panels for silkscreening, I have to use inches on the drawings, even if everything else is metric.
I've actually heard about this before. How long ago did you encounter this?
Matt Lorono
Silicon Valley, CA
The final product comes from Canada (metric), my tooling (USA) is in imperial. In order for things to work, my drawings use dual dims, metric secondary. The machinist complained at first, but I told him to stop b*tching...both dims are on the dwgs! There I stand.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Your company is making a very big mistake and the people who would like to return to the steam engine are making the same goofy arguments for mixed drawings etc.
Stick to your guns. I know it's like fighting windmills but if your company does not change their way of thinking - find a new job. The will not survive in a worldwide economy.
That was a fun one to try and explain to the machine shop.
Engineering is the art of modelling materials we do not wholly understand, into shapes we cannot precisely analyse so as to withstand forces we cannot properly assess, in such a way that the public has no reason to suspect the extent of our ignorance.
-A R Dykes
Matt Lorono
Silicon Valley, CA
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
All the metric bolts I have observed in cars have their grade marked on them. Any bolt with a code like 8.8, 10.9 or 12.9 on top is metric. I have not paid attention to older cars, but I assume that English bolts are marked too. You just have to read up on it.
If it were me checking the drawings, I would not accept M39x26TPI as a thread specification.
How about 1.5354-26UN? or 1.5354(39mm)-26UN
The UN thread with weird diameter is not ideal practise, but it is acceptable. It is not really any weirder than something like 1.350-20UN, which I am pretty certain I have seen around. 26TPI looks weird too, although I just found some 27TPI threads in my Machinery's Handbook.
The M39 part indicates a metric thread, which is a different profile. I do not think this should be mixed with an English pitch. M39X0.977 would be evil.
Is there any reason they just did not do M39X1?
I have not checked carefully. The specifications are mostly the same, with the 60° angle. I am sure there are niggling details that do not agree.
It is actually a Whitworth thread profile, although we have never had it called out as such. When I started with the company it was called out as an M39x1, and was working fine. We never had any problems, but I have read online about some Russian lenses that were done with the 1mm pitch that had problems with the 26TPI mount.
The error was pointed out to me, so I tried to give it the correct callout. Everywhere I found it online it was always referred to as an M39x26TPI. I should probably change it to 1.5354-26 as suggested, although the rest of the drawing is metric so that would be mixing the two standards again.
I mostly wanted to point it out as it seemed to be a prime example of what the OP is talking about, mixing metric and imperial.
-A R Dykes
On a metric drawing, a 1/4-20UNC thread is called up as 1/4-20UNC. UN is dimensioned in inches. Unified National is a different specification from metric, and from Whitworth. I remember seeing a camera with the tripod thread specified as 1/4-20BSW. I asked around to see if it was possible to insert a 1/4-20UNC screw into a 1/4-20BSW hole. The Whitworth thread definitely has a different profile from UN and from metric.
You are able to cross-thread this stuff because you are only engaging one or two threads.
You are right, the Whitworth is a 55° thread. I have never seen them anywhere before this part so I don't know if there is a 60° version as well (Machinery's Handbook doesn't list any).
Drawoh,
Thanks for clarifying that for me. Our company has never really cared for the quality of the drawings (managements attitude seems to be that if we can built a prototype in ths shop it is ready to be sold, I had to fight to get a copy of Y14.5).
In our case the lens we use only has three threads (revolutions of thread) to engage, so the minor differences between a 1mm pitch and a 26 TPI have not affected us, yet. As for the difference between the 55° and the 60° thread profile, is this something that I should worry about?
Sorry for hijacking the thread.
-A R Dykes
If I'm thinking about it correct, one combination of 55 & 60 may work, the other way round wouldn't. I think a 55 screw might go into a 60 nut but I'd have to draw it out to convince my self. The other way would wouldn't work due to difference in the pitch & minor diameters.
Matt Lorono
Silicon Valley, CA
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
I get a good chuckle when people get all worked up about metric vs inch ... it's an "US (pun-intended) vs Them" argument that's absurd. We made the switch about 30-plus years ago and we still work in both units and have full availability of components in both dimensional units. If you look realistically at the US industial base now, you'll see that the driving industries are metric-based now, and have been for what ... 15-20 years now? Automotive ... do you need a 1/4" socket or a 6mm socket on current products? Aerospace and defense systems are dominantly metric because of the international market and defence-alliance agreements. And if you want a real reality kick, look at what unit system is actually codified in the USA; it isn't the "US Customary" system.
I know from experience that it is often easier to find metric cutters, tools, taps, stock and whatever else you may need for manufacturing, in the US than it is in Canada ... we buy much of it from the States. As for the machining centres themselves, I've seen 60-year-old machines with encoders that were converted to metric. As long as you're using decimal fractions, there's no functional difference for the user; a number is a number is a number. And no, shops don't usually dump all their old tooling during a metric migration; they use the closest inch cutter (within tolerance) until it is consumed, then replace it with metric cutters. I've known many inch-trained machinists, millwrights and master mold makers who made the migration and a few that haven't; it's a resistance to change that is at issue, not the unit or the technology.
Consider the economics of the global situation now. The US sources a significant portion of its goods from Asia, EU and Canada, and reciprocally sells a lot of their goods to us. Personally, I try to do business in whatever unit is most convenient for my customer, and that's what US suppliers have been doing, and will do even more in order to survive.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
or "Black & Decker" etc. etc. are apparently designed in the US and the prints are than sent to China. Now you can find screws which are in inches (like 1/4-20) but with a metric hex or wrench size. Looks like someone here insisted on inch thread. That is what they gave you! Only, with a metric wrench size. You wonder how many of the parts on these US designed and China made tools are part inch and part metric?
The only thing that is holding back a fast and complete change to metric in the US, is the political will and if I had to compete with the US today I would hire lobbyists and pay off our representatives to keep our schools on the customary US system. Not so sure this is not the case already. What a cheap and easy way to cut down your competition.
We must start with our schools so our children will grow up thinking metric. Our media must stop dumbing down the American people by converting everything to inches, gallons and deg. Fahrenheit. Science moved to metric a long time ago and I am sure we do not want to become a country that is relying on agriculture only. Bushels anybody?
Tdculbert - sorry if I drifted away from your original posting.
Pah, who needs metric when the other option is so great?
My favorite unit is the miners inch, which varies by local statute:
* 1/60 ft³/s (472 mL/s) New Zealand
* 1/50 ft³/s (566 mL/s) southern California, Idaho, Kansas, Nebraska, New Mexico, North Dakota, South Dakota, Utah, Washington
* 1/40 ft³/s (708 mL/s) Arizona, northern California, Montana, Nevada, Oregon
* 1/38 ft³/s (745 mL/s) Colorado
* 1/36 ft³/s (787 mL/s) British Columbia
