Multiple layers with frictional sliding in between them
I have been trying to develop a 2 layered large scale model for geological applications. Due to the nature of the problem, I have to define contacts (10) between all surfaces that can come in contact with one another during the analysis.
When I run the model, it runs just fine for upto t = 0.08 (of a total of 1 unit) and the time increments begin becoming vanishingly small from this point forward. I tried my best to remove any over-constraints, but I cannot understand what is causing the problem.
I am attaching the cae file. Can somebody please suggest to me what may be wrong and if there is a more elegant way to define the contacts.
Thanks in advance
SS
Thanks in advance
SS
RE: Multiple layers with frictional sliding in between them
Rob Stupplebeen
In my case, I managed to avoid the situation by allowing seperation and holding the contacts together with 'tie' constraints. Hope that helps.
And completely unrelated: I looked at your cae file, and I'm wondering where you got the nice tabular data for the plastic behaviour of the granite and sandstone. Your own measurements? Some citable source?
I will try both your suggestions and see what happens. I will update the status on this thread.
Rmettier,
The elasto-plastic hardening values for Granite and Sandstone are from published articles. These are for testing my models only;
Here are the references
Sandstone : *Zhu, W., Montési, L. and Wong, T.-f. (1997) Shear-enhanced compaction and permeability reduction: triaxial extension tests on porous sandstone, Mechanics of Materials, 25, 199-214.
( I have included volumetric strains from this paper in my model - if you have any suggestions as to how I can do it, please let me know)
Granite: Tullis and Yund, 1977. J. Tullis and R.A. Yund, Experimental deformation of dry Westerly granite. Journal of Geophysical Research 82 (1977), pp. 5705–5718
