Fuse Terminals for Classified Area
To all-
I am adding 4 - 24VDC power supplies (Pheonix QUINT) to an existing NEMA 4X non-purged enclosure that exists within a Class 1 Div 2 Groups B&D environment. I am putting a non-arcing (rated) DIN rail mounted disconnect on the 120VAC primary side.
The QUINT has internal 5A protection, and does not REQUIRE additional protection. However, since the internal 5A is not user-replaceable I thought an external fuse would be good for operations. This is where I am having trouble!!!
Have any of you been able to find a Class 1 Div 2 Grp B&D fused terminal? I am having no luck. Weidmuller has a "new" item WSI 4/2, but it is rated in Canada only and their tech support did not recommend it be used for my application. Entrelec does not have anything that I found either and they are the preferred brand for my facility.
How have some of you handled this?
Why do you think it is such a problem to make one?
Thanks in advance,
Charles
Thanks in advance,
Charles
RE: Fuse Terminals for Classified Area
I suggest you look for a PTC (positive temperature coefficient) type fuse. Bourns has some components that are recognized by TUV, so someone might have designed these into a block rated for Class 1 Div 2 environment.
John D
Dan Marr
"Real world Knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity."
Dan Marr
Eric Kench, P.E.
