Perforated piping to be used as distributor
Could you please tell me if there is any standard that state how to carry out calculations regarding perforated piping to be used as water distributor. Number of holes and holes flow area
Your help will be highly appreciated
RE: Perforated piping to be used as distributor
psafety
thread391-180020: balancing flow through perforated pipe
thread164-231082: Design of pressure line orifices for equal distribution
Thanks a lot for your support, however I want to share with all of you the results of my search.
Perforated piping design can be found in Chapter # 6 of the Perry´s Chemical Engineer Handbook. You will find an example about it.
Best Regards
