EDT 150 distortion
EDT 150 distortion
We are currently using ETD 150 for a 2-1/2"Ø shaft that requires a 3/8" x 1/4" Keyway 10" long. The part is warping up after machining what can I do to prevent this?
RE: EDT 150 distortion
A better alternative is a material called FLEXOR. FLEXOR has higher alloy content than 4140. When it is rolled or forged it will air cool to 30 HRC. FLEXOR is very stable through machining and will exhibit higher properties than ETD 150. (for example: FLEXOR charpy impact in ft/lbs is 86 vs ETD 150 which is typically less than 10). FLEXOR even maintains though hardness up into the large diameters 11"-12". Go to Pennsylvania Steel Corporation – they are a single source for this material. (www.pennsylvaniasteel.com).
I would conduct a low temperature stress relief treatment before deciding on switching steels. This can be accomplished with a local heat treatment company.
