GROUP MACRO
GROUP MACRO
GROUP MACRO
Hi all,
I would like to select notes/balloons and group them together. How do I create the macro without pre-selecting the notes ahead of time. I am planning to use a hot key.
RE: GROUP MACRO
You should traverse either the Drawing View in Drawing Document or Model doc in Part/Assemblies.
Use View::GetNotes method to get notes from this drawing view. Refer "Get Views and Notes (VB6)" example in the API Help
You can also traverse all annotation with ModelDoc2::GetFirstAnnotation2 and Annotation::GetNext3 methods and check their types with Annotation::GetType method.
Next use Annotation::Select3 method to select the annotation.
Artem Taturevich
CSWP
RE: GROUP MACRO
I'm not really understanding what workflow you are looking for.  You want to activate some "group" command and then select your notes/balloons?  What exact sequence of user action is your goal?
-handleman, CSWP (The new, easy test)
RE: GROUP MACRO
Artemtat
Not comfortable with much API but are working on it. Thanks
handleman
I'm looking to save mouse clicks. I would like to select notes I want to group and hot key to group. Or hot key then select.
RE: GROUP MACRO
It looks as though you want the macro to start, then determine if anything is selected.  If yes, then group.  If no, then ask for selection.  Once selection is complete, click on some "OK" button.  Then group selection.
Is this correct?
The assignment to a hotkey should not be done.  Use a shortcut key instead, which is done after the macro is complete within customization window.  That way you can active the macro when every you want, and not have it running all the time for no reason.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: GROUP MACRO
Really not sure what Matt's last paragraph means.  Here is a macro that you can map to a shortcut key.  Running this macro has the exact same result as RMB->Group->Group.  However, if the selected annotations include an annotation that cannot be grouped (i.e. it belongs to a different view), nothing will happen.
CODE
Sub main()
Application.SldWorks.ActiveDoc.CreateGroup
End Sub
RE: GROUP MACRO
Ah.  Never would've thought of that interpretation!
