CVT accuracy for different loads
Hi everybody
As we know in IEC mentioned that because of keeping the accuracy,load of CVT should be 0.25% to 100% nominal burden of CVT anf If the load is less than 25% nominal burden,accuracy of CVT will reduce.I would like to know that is there any relashin beween load and accuracy,e.g if the burden of CVT is 10VA with accuracy 0.5+3p and our load is 1 VA,then according to IEC the accuracy will reduce,Is there any relation that shows us that how much accuracy reduced and what will be the accuracy in this case?
RE: CVT accuracy for different loads
http
Marmite
Please see attached thread on the topic.
thread238-243315: VT, PT load.
And of course read document is attached by Marmite.
Best Regards.
Slava
