How to link to files/pictures correctly
Recently, I've posted some jpgs on the forum....then thought it would be better to use ENGINEERING.com to link to so as not to make the original post so huge and cumbersome to read.
After some nosing around on ENGINEERING.com , I finally got to the place where you can upload pix. (That took a while to find)
OK...
So, how do you make a link to the picture (or other file) so that it is the only thing that shows; in other words, what is it that you copy/paste into Step4, Attachment so that others only see the intended picture and not the whole logged-in user's albums, etc?
OK...
RE: How to link to files/pictures correctly
... or upload your file to ENGINEERING.com
after that, it is pretty self explanatory.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
what is the [b] ?
Also, can more than 1 jpg file at a time be linked to?
If so, how?
Just use the ...or upload your file to ENINEERING.com link below. You don't need to use your personal ENGINEERING.com membership access to upload files.
ZIP multiple files before uploading, and just post the links rather than the code to display the image(s). Images slow the thread too much for those without a high speed connection.
