Helicoils
Helicoils
If I require to insert a helicoil in a bore deeper than the individual insert, can the inserts be inserted consecutively to the full depth?
Thanks in advance,
Rod
Thanks in advance,
Rod
Rod Nissen.
Combustion & Engineering Diagnostics
RE: Helicoils
The helicoils that I'm familiar with have a small leg (tang) in the center of them so that the insertion tool has something to grab onto when the helicoil is inserted into a hole.
I'm not sure that even after you break the tang off the bottom of the second helicoil if the threads will line up from one helicoil insert to the next.
As the fastnener is screwed through the top helicoil, and it begins to enter the lower helicoil the threads of the bottom helicoil may not be in axial alignment with the top and the fastener will effectively bottom out.
I have attached a link to a brochure that has pictures of various helicoils.
http://w
It's quite possible that there is something else out there that would do as you describe, that's the extent of my experience with helicoils...
Hope this helps.
Kyle
RE: Helicoils
Mike
RE: Helicoils
Rod.
Rod Nissen.
RE: Helicoils
RE: Helicoils
That should include everything you ever wanted to know about heli-coils. From the horses mouth if it were.
James Spisich
Design Engineer, CSWP
