ASME Interpretation : Pipe vs. Vessel
I remember reading once about an interpretation in section VIII that defined when section VIII applies and when B31.3 applies and it said that essentially if used as a pipe it is B31.3, if used as a vessel it is section VIII. I have a new "vessel" that will be used in service up to 30psig, will be made out of 8" sched 40 pipe and will be used as a vessel...therefore it needs to be certified as a pressure vessel, correct?
Anyone know where I can find this interpretation?
RE: ASME Interpretation : Pipe vs. Vessel
No, not necessarily. Review the Scope of ASME Section VIII, Div 1, specifically U-1(c)2 and (h). Piping by design should convey fluids.
to clarify...my "vessel" will be used as a vessel. It will contain a variable amount of liquid, level switches to determine when to allow it to fill and when to drain it, smaller piping for inlet/outlet/equalizing/etc.
Per U1(c)2 ...which serve such purposes as mixing, separating, snubbing, distributing...etc.
Mine will be used as a surge tank...its only association with piping is that it will be made of one.
Well, you found your answer. I'll throw another request that you can follow-up on - check with your local Jurisdiction as to what they recommend for this vessel. The reason is this - you should design and fabricate the vessel to ASME Section VIII, Div 1 but your local Jurisdiction has the final say regarding registration, inspection and issuance of an operating certificate for this vessel.
In your original post you stated that you vaguely recalled an Interpretation which dealt with this. I suspect you may be referring to Int. VIII-1-04-47 in which the question is basically "If I build a vessel out of pipe and end caps but I don't meet any of the exemptions in U-1(c)(2), is it out of the scope?" to which the reply is "No."
jt
I need to get an updated copy of section VIII, I my 1992 copy doesn't have the 2004 interpretation referenced above or section h in the intro.
I'm blown away by the fact that the 1992 edition of ASME VIII is still being used for design - I agree it's time to get a new version.
