Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...(I) have been able to get my problems solved from past messages and also new posts that other users have responded to promptly..."
Geography
AlyB (Mechanical)
1 Jun 09 10:31
Anyone know whether using concrete in a high sulfur environment is a bad idea?
I know sulfur is added to concrete, but I couldn't find any info on sulfur in the environment.
Thanks!
iandig (Civil/Environmental)
1 Jun 09 12:20
Sulfate is very very very bad for concrete, and when sulfur oxidises it forms sulfate. Not something I would do without proper design and assessment. If in UK, refer to the BRE Special Digest on Concrete in Aggresive Ground.
PST09 (Civil/Environmental)
10 Jun 09 5:03
Hi AlyB.  If you concrete is in ground with potentially high sulphate levels i would sepcify concrete with a high chemical resistance.  Something like design chemical class DC-3.
Pete
Ron (Structural)
10 Jun 09 5:41
Both sulfates and weak acids that form when sulfur is exposed to moisture will attach concrete.  The attack is primarily to the cement paste, but can attack certain aggregates as well.  In either case, it is not good.
If it is only sulfate exposure, you can use a high sulfate resisting cement (Type V),or if only mild sulfate exposure, Type II cement has some resistance.
AlyB (Mechanical)
10 Jun 09 15:35
Good to know, thanks folks.
DMcGrath (Civil/Environmental)
11 Jun 09 21:43
The Virginia DOT has a research program dedicated to high-sulfur soils - concrete degredation is part of the problem.  This presentation has a couple of good examples of concrete attacked by high-sulfur soils:  http://www.cses.vt.edu/revegetation/Papers%20PDF/Acid%20soils%20in%20VA%20highways%20talk.pdf
Close Box
Join Eng-Tips® Today!
Join Us             Close
