Can STAAD.Pro v8i Merge Specifications?
Is there a way in STAAD to merge specifications, similar to what Merge Properties on the Tools menu does?
For example when I have a big model and I finish assigning the End and Start Releases. On my specification window I only have 2 lines one for the end release and one for the start release. No if I save and close the program and then open it, the 2 Specifications will be split into 4 or 5 each so I end up with 4 or 5 End Releases and 4 of 5 Start Releases. Now if I continue to assign releases with any of the 5 specification lines that showed up, and do the same process of saving, closing and opening the model it will again keep splitting the lines. So I may end up with 10 End Releases and 10 Start Releases that do the same thing but are assign to different members.
So I would like to go back to only 1 End Release and 1 Start Release.
