Ground water resistivity
If we want to measure ground water resitivity for desiging a ground system for a station what is the procesure?
We conducting a ground water resistivity test on the site or take a sample for measuring the resistivity?
RE: Ground water resistivity
Typically, you are interested in the resistivity of the soil/water combination, not the water alone.
"The more the universe seems comprehensible, the more it also seems pointless." -- Steven Weinberg
How about to measure water resistivity as a return path for fault current in a hydroelectric dam that uses a penstock or a tunnel for carrying the water.
As far as I know only sea water is used for grounding purpose [Cathodic Protection of Metallic Structures as bridges -for instance].
From  http://www.smeter.net/grounds/soil-electrical-resistance.php :
Freshwater lakes, unpolluted   1000 ohm.m
Sea water, away from river estuaries   0.22 ohm.m
The water will not be there all the time in the case of a penstock.   Fresh water is actually not a great conductor.   Pure water is not a conductor at all.
