UL CODE ON PREWIRING LIGHTING FIXTURE AT 240 VOLT
i AM A CANADIAN FIXTURE MANUFACTURER IN CANADA 240V BALLASTS MUST HAVE AN ISOLATED SECONDARY IN ORDER TO HAVE CSA CERTIFICATION.
DOES THE SAME HOLD TRUE WITH THE UL CODE.
WILL UL BE VOIDED IF I PREWIRE A QUAD TAP BALLAST TO 240V
ARE THERE ANY REGULATIONS?
RE: UL CODE ON PREWIRING LIGHTING FIXTURE AT 240 VOLT
