Profile Control of Datum
Please see the attached drawing.
I am using ASME Y14.5-2009, I think the '94 version would have "two surfaces" in place of my "2x", but anyway...
Profile of a surface requires the true profile to be established with basic dimensions. I can't find anything in the standard that overrides this rule when the surface is a datum as I have shown. I don't want the .500 width to be basic, I just want those 2 edges to be within .005 and to establish datum B.
Is it acceptable the way I have it?
RE: Profile Control of Datum
There are some very explicit examples in the 94 standard for using surface profile to control coplanarity and even as setting that as a datum. I'd assume 09 is the same so take another look if you haven't already.
You're setting the 'under side' of the tabs as your B datum. The .500 doesn't come into making the datum or not. The .500 (should maybe be 2X) is locating the top edge of the tab from datum B.
All other features in that orientation should be dimensioned (directly or indirectly) from B unless you have something funny going on.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Attached is one example but there are other ways to do it as well.
Paul
JLang's repost appears pretty clear to me, very similar to figure 6-20 in the 94 spec. The phantom line makes it clear which 2 surfaces it applies to, although there should be a break between the phantom line & the geometry line.
I'm not sure about the "2X" but the OP implies this is a 2009 thing.
KENAT,
