Please help me with this problem....
Hey guys does anybody know the best way to replicate this cutout onto all of the faces going round. please see the attached image.
Cheers
RE: Please help me with this problem....
circular pattern will do it
dy
Wow thanks alot! thats exactly what i wanted!
Cheers,
could you explain briefly how you went about drawing this 12 sided shape, i managed it after alot messing around but wondered if i was missing somthing simple.
I'm lazy winky smile, I used a small program from this site: Polygon
dy
phudge, there's a macro provided with SE that does that. It is located in Program Files\Solid Edge\Custom\nSidePolygon.
You can create a new toolbar button and attribute it to the macro. It takes some time for it to load, it's not as fast as a regular tool.
Personaly I prefer to do it the manual way. From the look of your screen capture, I think I'm doing it the same way as you.
- Start with a circle, convert it to a construction element
- Draw contiguous lines and taking care always "snaping" the endpoints to the circle. The polygon is inscribed within the circle.
- Assign equal relationships to all the line segments
- Dimension either the circle or a line segment, position the circle to the origin so the polygon is fully constrained.
