Morse taper stainless bronze
Morse taper is typically used on tool steels. Has it been tried with a stainless-bronze interface? The reason for the corrosion resistant materials is, the connection will be underwater for awhile and we hope to be able to get it apart. But will the torque resistance work between bronze and stainless? Are some corrosion resistant alloy/heat treat mates better or worse than others?
thanks.
thanks.
RE: Morse taper stainless bronze
this is the worst crevice corrosion cell that you could build, so prepare to be disappointed.
Plymouth Tube
