Make all blocks grey
I have some floor plans that I need to add various service layouts to (electrical, data, fire alarm, air-con etc..)
The original drawings have numerous blocks that are unable to be exploded and are different colours.
Is there an easy way to grab everything and make it a single colour. All the non-block items are fine, but the blocks stay as they were. I have to manually edit all the blocks to make them explodable.
RE: Make all blocks grey
I think you could find a lisp in the www, that would change the nested objects to "By Layer"
Which ACAD-version are you running?
Lothar
ADT 2004
lisp is not running with LT.
Maybe you can work with a *.ctb file. But the objects on the screeen would not change their colour.
So you have to edit the blocks manually
No more alternatives, Lothar
ADT 2004
